Re: [Texo] NPE in TexoGeneratorApplication [message #1704121 is a reply to message #1703980] |
Fri, 07 August 2015 08:57   |
Indeed a bug.., can you enter a bugzilla for it?
I started to repair it. Should be available by tomorrow.
gr. Martin
On 06-08-15 23:28, Adrian Rumpold wrote:
> I'm having some trouble when invoking Texo's code generation through the Equinox launcher from the command line (I'm
> trying to integrate the code generation process in my Gradle build setup).
> Specifically, I run into a NPE from L352 in
> GeneratorUtils.readEPackagesUsingEMFURI(final List<URI> uris, ResourceSet resourceSet, EPackage.Registry registry)
> which is invoked in L331 through the overload GeneratorUtils.readEPackagesUsingEMFURI(final List<URI> uris,
> Since the two parameter version supplies null for the ResourceSet, the null pointer access is guaranteed. Maybe the
> second parameter was intended to be the return value of the otherwise unused method
> GeneratorUtils.createGenerationResourceSet?
> I'm using the latest available version of Texo on Eclipse Mars (0.9.0.v201508051411).
> If anybody has encountered this problem before and knows a workaround, I would be most grateful! Thanks for your
> responses in advance! :)
> Best,
> Adrian
> Attached stacktrace:
> java.lang.RuntimeException: Exception for model file
> file:/C:/Users/Adriano/MDSD4SIL/EAMetamodel/model/enterprise_architect.ecore
> at org.eclipse.emf.texo.eclipse.generator.TexoGeneratorApplication.generateCode(TexoGeneratorApplication.java:167)
> at org.eclipse.emf.texo.eclipse.generator.TexoGeneratorApplication.start(TexoGeneratorApplication.java:135)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
> Caused by: java.lang.NullPointerException
> at org.eclipse.emf.texo.generator.GeneratorUtils.readEPackagesUsingEMFURI(GeneratorUtils.java:352)
> at org.eclipse.emf.texo.generator.GeneratorUtils.readEPackagesUsingEMFURI(GeneratorUtils.java:331)
> at org.eclipse.emf.texo.eclipse.generator.TexoGeneratorApplication.generateCode(TexoGeneratorApplication.java:174)
> at org.eclipse.emf.texo.eclipse.generator.TexoGeneratorApplication.generateCode(TexoGeneratorApplication.java:165)
> My launcher invocation looks like this:
> java -jar
> c:/Users/Adriano/Desktop/Development/eclipse-modeling-mars-R-win32-x86_64/plugins/org.eclipse.equinox.launcher_1.3.100.v20150511-1540.jar
> -data C:/Users/Adriano/MDSD4SIL -application org.eclipse.emf.texo.eclipse.generator.TexoCodeGenerator -modelLocation
> C:/Users/Adriano/MDSD4SIL/EAMetamodel/model -projectName EAMetamodel.model
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] NPE in TexoGeneratorApplication [message #1704172 is a reply to message #1704121] |
Fri, 07 August 2015 16:50   |
I published a new build with a bug fix, can you check if it works for you?
If you can still enter a bugzilla for it then I can report against it.
gr. Martin
> gr. Martin
>> Hi,
>> Best,
>> Adrian
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> java -jar
The Netherlands
Re: [Texo] NPE in TexoGeneratorApplication [message #1704882 is a reply to message #1704172] |
Mon, 10 August 2015 08:10  |
Hello Martin,
thanks for your quick reply and the fix! I tested the most recent build and everything seems to be working smoothly now when I invoke the headless code generation.
As you requested, I reported the issue on Bugzilla for reference, you can find it here.
Best,
Adrian
FUDForum. Page generated in 0.04159 seconds
