Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMF Form(when render or preview the Form View , the cross reference between elements in different ecore are not recognized )
EMF Form [message #1703976] Thu, 06 August 2015 06:09 Go to next message
Hi ,
I am new to EMF Form ,
I would like to integrate the form with my EMF Model Editor. However, when I generate the view out of my ecore file , I noticed that :
1) for any EClass (A) that inherits another EClass (B) , The attribute of A do not rendered by emf form.
2) the reference relations between EClasses across multiple ECore models are not recognized as well by the EMF Form.
I get this message once i try to run my RCP Editor :
MESSAGE Not resolved: org.eclipse.emf.ecp.view.spi.model.impl.VFeaturePathDomainModelReferenceImpl@470cfc1f (changeListener: null) on control org.eclipse.emf.ecp.view.spi.model.impl.VControlImpl@457a0993 (name: Control dependentOn, visible: true, enabled: true, readonly: false) (labelAlignment: Left)
Can you please help me with this .
[Updated on: Thu, 06 August 2015 06:48] by Moderator
Re: EMF Form [message #1704088 is a reply to message #1703976] Fri, 07 August 2015 05:12 Go to previous messageGo to next message
Hi Salwa,
did you create an explciti view model? Can you add the missing controls
using the action "generate controls" in the view model editor?
Best regards
Jonas
Am 06.08.2015 um 12:09 schrieb Salwa Alzahmi:
> Hi ,
Jonas Helming
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: EMF Form [message #1704886 is a reply to message #1704088] Mon, 10 August 2015 08:30 Go to previous messageGo to next message
Thankx for your reply.
I actually try to use generate cntrol, but that EAttribute (dependOn) and others of my EClass and showing in the wizard ! ..
Re: EMF Form [message #1705006 is a reply to message #1704886] Tue, 11 August 2015 07:41 Go to previous message
I am not sure, if I understand your last post. Do you mean ".. of my
EClass are not showing ..."?
Can you post a sample model explaining the issue more in detail?
Best regards
Jonas
Am 10.08.2015 um 14:30 schrieb Salwa Alzahmi:
> Hi Thankx for your reply.
Jonas Helming
Previous Topic:[Texo] NPE in TexoGeneratorApplication
Next Topic:[EMF Forms] order of getter/setter calls
Current Time: Sun Jul 27 10:03:48 EDT 2025
Powered by FUDForum. Page generated in 0.03832 seconds
