[Teneo Auditing] TENEO_CONTAINER_FEATURE_ID maintenance after model changing [message #1703838] |
Wed, 05 August 2015 05:34  |
Hello newsgroup,
We have the problem that in the auditing DB Tables the TENEO_CONTAINER_FEATURE_ID will be saved for containing model classes. This causes the problem that if we add a new feature to the model class, which have this containing class, and the feature will be inserted in the model before the contained feature, than the feature id for all subsequent features in the model will be shift by 1.
This will cause that in old data sets in the auditing DB tables the TENEO_CONTAINER_FEATURE_ID is wrong.
So the question is: Can it be changed like in the forum post http://www.eclipse.org/forums/index.php?t=msg&th=135941/ instead of the feature id to the feature name?
Many thanks in advance,
Doris
Re: [Teneo Auditing] TENEO_CONTAINER_FEATURE_ID maintenance after model changing [message #1703937 is a reply to message #1703838] |
Wed, 05 August 2015 19:24   |
Hi Doris,
Yes this can be changed, can you enter a feature request/bugzilla for it?
Which teneo version are you using?
I prefer to do this in the latest version of Teneo which is 2.1.0.
gr. Martin
On 05-08-15 20:44, Doris Schuenemann wrote:
> Hello newsgroup,
> Doris
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo Auditing] TENEO_CONTAINER_FEATURE_ID maintenance after model changing [message #1703997 is a reply to message #1703952] |
Thu, 06 August 2015 09:46  |
Hi Doris,
Okay I will change it in the 2.0.1 also, this part of the code is the same for both versions, so I can probably create
one diff for both.
gr. Martin
On 06-08-15 08:37, Doris Schuenemann wrote:
> Hello Martin,
> thank you for your quick response.
> We have reported a bugzilla:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=474379
> We need the update in version 2.0.1 of teneo, because our application can't be updated to Eclipse 4.
> Thanks in advance
> Doris
The Netherlands
FUDForum. Page generated in 0.03924 seconds
