Home » Eclipse Projects » Oomph » Automate keybinding configuration
Automate keybinding configuration [message #1703650] Mon, 03 August 2015 16:26 Go to next message
Hi!
I have a question about configuration of key bindings as part of the product setup process.
There is an option to add Key Binding, which works fine.
But, is there an option to clear existing bindings for a command (e.g. to override key bindings instead of adding new binding) ?
From the other side, is it possible to remove conflicting binding (e.g. when I add a key sequence that is already used, I would like to remove old binding).
Thanks for suggestions in advance,
Re: Automate keybinding configuration [message #1703831 is a reply to message #1703650] Wed, 05 August 2015 05:06 Go to previous messageGo to next message
Am 03.08.2015 um 23:00 schrieb Marek Budyn:
> Hi!
> binding) ?
The KeyBindingTask was only meant to add new bindings, but I imagine we could enhance it to do what you describe. Please
open an enhancement request.
Cheers
/Eike
http://www.esc-net.de
Re: Automate keybinding configuration [message #1848511 is a reply to message #1703831] Mon, 06 December 2021 08:01 Go to previous message
I have encountered similar issue. I searched in bugzilla and the task is still unresolved.
Is there any workaround how to unbind keys?
Thanks in advance.
Previous Topic:How to add maven dependencies for Targlet?
Next Topic:setup:PreferenceTask is ignored in Setup Product Model
Current Time: Sat Jun 07 05:56:32 EDT 2025
Powered by FUDForum. Page generated in 0.06775 seconds
