Home » Eclipse Projects » Lyo » Update example applications to Java 8
Update example applications to Java 8 [message #1703231] Wed, 29 July 2015 10:48 Go to next message
I'm quite new to the OSLC and to become familiar with the technique, I
ran the examples, which are provided at
http://open-services.net/resources/tutorials/integrating-products-with-oslc/running-the-examples/.
I used Eclipse Mars, which suites the needs as "Eclipse 3.6 or later".
But during building and executing the example applications, I had to
notice, that there are several problems using Java 8, which is default
for Eclipse Mars. So instead to download and configure Java 6, I
modified the sources to build and run on Java 8 correctly.
Now, my question is: Is anybody interested in these updated projects?
How can I contribute the modified code?
Joachim
Re: Update example applications to Java 8 [message #1703349 is a reply to message #1703231] Thu, 30 July 2015 18:25 Go to previous messageGo to next message
Hello Joachim,
We'd be happy to get code that's updated for Java 8. Instructions for contributing to Lyo are here. However, there's some setup involved and you'll need to electronically sign the Eclipse Contributor License Agreement. When you contribute your changes you should reference the Migrate Lyo to Java 8 Bugzilla.
If this is too much overhead, you can describe the changes you made in a comment or attachment in the Bugzilla. I can use that information to make the changes myself.
Thanks for the contribution!
Re: Update example applications to Java 8 [message #1703431 is a reply to message #1703349] Fri, 31 July 2015 09:42 Go to previous message
Hello Jim,
in the past, I often want to know, how to contribute to Eclipse
projects, but I never tried it nor had the confidence to do it. I'm only
familiar with SVN and do not know much about git and gerrit.
So after a quite long time of configuration and reading about the
process to contribute changes via gerrit, I got it and did my first push
into the lyo.core gerrit repo.
Hopefully, I did it all right. Changes for the examples from the
mentioned tutorial will follow (lyo.docs & lyo.server).
Previous Topic:Missing nesting capabilities of ServiceProviders
Next Topic:Anyone going to All Things Open or REST Fest 2015 this year
Current Time: Wed Jul 23 18:35:00 EDT 2025
Powered by FUDForum. Page generated in 0.05026 seconds
