Home » Newcomers » Newcomers » Console out put message(Added message in console when java application run)
icon4.gif  Console out put message [message #1702848] Sun, 26 July 2015 02:12 Go to next message
Short piece of learners code:
public class MyFirstJavaClass {
* @param args
System.out.println("Chocolate, royalties, sleep");
Console output:
Picked up JAVA_TOOL_OPTIONS: -javaagent:/usr/share/java/jayatanaag.jar
It should only display Chocolate. royalties, sleep
What have I done wrong
Thank you
Brian
Re: Console out put message [message #1702863 is a reply to message #1702848] Sun, 26 July 2015 11:06 Go to previous messageGo to next message
> * @param args
> public static void main(String[] args) {
> Console output:
> Thank you
> Brian
In the Eclipse Console View, you mean?
Re: Console out put message [message #1702927 is a reply to message #1702863] Mon, 27 July 2015 08:09 Go to previous messageGo to next message
Not in the console, but when I installed java or when I installed Eclipse.
History: previous computer died so replaced it, and installed ubuntu 15.04 amd 64 version
re-installed java and eclipse. Previous computer had 32 bit ubuntu installed and the out- put in the console was " Chocolate. royalties, sleep"
It did not include the text in Red "Picked up JAVA_TOOL_OPTIONS: -javaagent:/usr/share/java/jayatanaag.jar"
Re: Console out put message [message #1702984 is a reply to message #1702927] Mon, 27 July 2015 13:04 Go to previous messageGo to next message
> sleep"
If this is the behavior in your operation system's console (terminal
window), then I'm struggling to see how it's an Eclipse question or how
you'll get an answer in this forum. Maybe I still misunderstand.
Re: Console out put message [message #1703161 is a reply to message #1702984] Wed, 29 July 2015 00:49 Go to previous messageGo to next message
May I explain a little more fully, that is what I get in the Eclipse console, when I run that short piece of code that has been typed into the Eclipse editor. The first line in red text, with the second line being the correct output.
Re: Console out put message [message #1703208 is a reply to message #1703161] Wed, 29 July 2015 07:44 Go to previous message
This happens because the environment variable JAVA_TOOL_OPTIONS is set.
The JVM is printing this to stderr.
You need to unset the environment variable to prevent it from printing.
See:
http://stackoverflow.com/questions/26074446/picked-up-java-tool-options-javaagent-usr-share-java-jayatanaag-jar-when-st
http://stackoverflow.com/questions/30213807/how-to-suppress-picked-up-java-tool-options-javaagent-usr-share-java-jayatan
https://community.oracle.com/thread/1239778?start=0&tstart=0
Previous Topic: Where is the resources section now that was in this site now?
Next Topic:open and run saved java program
Current Time: Sat Jul 26 20:57:54 EDT 2025
Powered by FUDForum. Page generated in 0.11826 seconds
