Home » Archived » Gyrex » Cannot set the request filter to my JaxRsApplication
icon5.gif  Cannot set the request filter to my JaxRsApplication [message #1703085] Tue, 28 July 2015 10:00 Go to next message
I have my own jaxrs application which extend JaxRsApplication, and I try to add customized container request filter, but It cannot work. Could you please help me to find out my mistake?
package com.octech.mamalianmeng.httpservice.application.base;
import java.util.ArrayList;
import java.util.List;
import javax.ws.rs.core.Application;
import org.eclipse.gyrex.context.IRuntimeContext;
import org.eclipse.gyrex.http.jaxrs.JaxRsApplication;
import com.sun.jersey.api.core.DefaultResourceConfig;
import com.sun.jersey.api.core.ResourceConfig;
import com.sun.jersey.spi.container.ContainerRequestFilter;
import com.sun.jersey.spi.container.ContainerResponseFilter;
public abstract class AbstractMumUnionJaxRsApplication extends JaxRsApplication {
	public AbstractMumUnionJaxRsApplication(String id, IRuntimeContext context) {
		super(id, context);
	protected Application createJaxRsApplication() {
		Application application = super.createJaxRsApplication();
		if (application.getClass().getName().equals(DefaultResourceConfig.class.getName())) {
			DefaultResourceConfig defaultResourceConfig = (DefaultResourceConfig) application;
			this.setContainerRequestFilters(defaultResourceConfig);
			this.setContainerResponseFilters(defaultResourceConfig);
			return defaultResourceConfig;
		} else {
			return application;
	 * 设置请求过滤器
	 * @param defaultResourceConfig
	private final void setContainerRequestFilters(DefaultResourceConfig defaultResourceConfig) {
		if (defaultResourceConfig == null) {
			return;
		List<Class<?>> containerFilters = this.getContainerRequestFilters();
		if (containerFilters != null && containerFilters.size() > 0) {
			List<String> filters = new ArrayList<String>();
			if (defaultResourceConfig.getProperties().containsKey(ResourceConfig.PROPERTY_CONTAINER_REQUEST_FILTERS)) {
				filters.add((String) defaultResourceConfig.getProperty(ResourceConfig.PROPERTY_CONTAINER_REQUEST_FILTERS));
			for (int i = 0; i < containerFilters.size(); i++) {
				if (ContainerRequestFilter.class.isAssignableFrom(containerFilters.get(i))) {
					filters.add(containerFilters.get(i).getName());
			defaultResourceConfig.getProperties().put(ResourceConfig.PROPERTY_CONTAINER_REQUEST_FILTERS, filters.toArray());
	 * 设置相应过滤器
	private final void setContainerResponseFilters(DefaultResourceConfig defaultResourceConfig) {
			return ;
		List<Class<?>> containerFilters = this.getContainerResponseFilters();
			if (defaultResourceConfig.getProperties().containsKey(ResourceConfig.PROPERTY_CONTAINER_RESPONSE_FILTERS)) {
				filters.add((String) defaultResourceConfig.getProperty(ResourceConfig.PROPERTY_CONTAINER_RESPONSE_FILTERS));
			for(int i = 0; i < containerFilters.size(); i++) {
				if (ContainerResponseFilter.class.isAssignableFrom(containerFilters.get(i))) {
			defaultResourceConfig.getProperties().put(ResourceConfig.PROPERTY_CONTAINER_RESPONSE_FILTERS, filters.toArray());
	 * 返回请求过滤器的类数组,filter的执行顺序以加入list中的顺序为准
	 * @return
	protected abstract List<Class<?>> getContainerRequestFilters();
	 * 返回相应过滤器的类数组,filter的执行顺序以加入list中的顺序为准
	 * @return
	protected abstract List<Class<?>> getContainerResponseFilters();
package com.octech.mamalianmeng.httpservice.application;
import java.util.Collections;
import java.util.HashSet;
import java.util.Set;
import com.octech.mamalianmeng.httpservice.application.base.AbstractMumUnionJaxRsApplication;
import com.octech.mamalianmeng.httpservice.application.filter.AuthorizationFilter;
import com.octech.mamalianmeng.httpservice.resource.OrderServiceResource;
public class DefaultMumUnionJaxRsApplication extends AbstractMumUnionJaxRsApplication {
	public DefaultMumUnionJaxRsApplication(String id, IRuntimeContext context) {
		super(id, context);
	protected List<Class<?>> getContainerRequestFilters() {
		List<Class<?>> filters = new ArrayList<Class<?>>();
		filters.add(AuthorizationFilter.class);
		return filters;
	protected List<Class<?>> getContainerResponseFilters() {
		return Collections.emptyList();
	protected Set<Class<?>> getJaxRsClasses() {
		Set<Class<?>> classes = new HashSet<Class<?>>();
		classes.add(OrderServiceResource.class);
		return classes;
Re: Cannot set the request filter to my JaxRsApplication [message #1703087 is a reply to message #1703085] Tue, 28 July 2015 10:02 Go to previous messageGo to next message
I add my request filter 'AuthorizationFilter' in DefaultMumUnionJaxRsApplication.
Re: Cannot set the request filter to my JaxRsApplication [message #1703101 is a reply to message #1703085] Tue, 28 July 2015 10:27 Go to previous messageGo to next message
I wonder if you could simply provide them as @Provider annotated
classes and use the bundle scanning feature. Is that possible with
filters?
-Gunnar
Gunnar Wagenknecht
gunnar@xxxxxxxx
Re: Cannot set the request filter to my JaxRsApplication [message #1703309 is a reply to message #1703087] Thu, 30 July 2015 09:29 Go to previous message
I had the same issue.
My soltion was
public class JaxRsAppExt extends JaxRsApplication {
    private ContextServiceInjectableProvider contextServiceInjector;
    private InjectServiceInjectableProvider injectServiceInjector;
    private final Bundle bundle;
    public JaxRsAppExt(final String id, final IRuntimeContext context, final Bundle bundle) {
	super(id, context);
	this.bundle = bundle;
    @SuppressWarnings("unchecked")
	final Application app = super.createJaxRsApplication();
	if (null != this.contextServiceInjector) {
	    app.getSingletons().add(this.contextServiceInjector);
	if (null != this.injectServiceInjector) {
	    app.getSingletons().add(this.injectServiceInjector);
	((ResourceConfig) app).getContainerRequestFilters().add(0, APIAuthFilter.class);
	((ResourceConfig) app).getContainerResponseFilters().add(0, APIAuthFilter.class);
	((ResourceConfig) app).getResourceFilterFactories().add(0, RolesAllowedResourceFilterFactory.class);
	return app;
    protected void doDestroy() {
	try {
	    // call super
	    super.doDestroy();
	} finally {
		this.contextServiceInjector.dispose();
		this.contextServiceInjector = null;
		this.injectServiceInjector.dispose();
		this.injectServiceInjector = null;
    protected void doInit() throws IllegalStateException, Exception {
	// create service injector
	this.contextServiceInjector = new ContextServiceInjectableProvider(this.bundle.getBundleContext());
	this.injectServiceInjector = new InjectServiceInjectableProvider(this.bundle.getBundleContext());
	// call super
	super.doInit();
	return new BundleScanningResourceConfig(this.bundle).getClasses();
Then you adding over porperties ir
[Updated on: Thu, 30 July 2015 09:31] by Moderator
Previous Topic:About the mounts of the JAX-RS demo
Next Topic:Why the created job cannot be started automatically.
Current Time: Mon Oct 27 11:14:12 EDT 2025
Powered by FUDForum. Page generated in 0.13506 seconds
