Home » Eclipse Projects » Eclipse Platform » Premature end of file under linux in CLI / not seen under Windows
Premature end of file under linux in CLI / not seen under Windows [message #1702441] |
Wed, 22 July 2015 07:18  |
We are developing small Eclipse based editor, since month we are getting problems during automated tests in installation to Eclipse.
We have not changed installation scripts, both are essential the same for Linux and Windows. Linux jobs fails with console error: Premature end of file, additionally it reports that some dependencies are not found ( mostly from emf package ). From time to time job passes. Windows jobs always end with success.
We tried to pinpoint issue by using different Linux distro, different networks (cloud, office, home), we even replicated p2. We have changed repo from luna to mars, the case repliccates with 2 month old builds which were working fine previously.
Do you have any comments what is the root cause ?
System specs:
Java(TM) SE Runtime Environment (build 1.8.0_45-b14)
installation&development platform Eclipse Luna sr2
win console:
+ eclipse/eclipse -application org.eclipse.equinox.p2.director -nosplash -consoleLog --launcher.suppressErrors -repository 'jar:file:org.temp.ide.eclipse.feature_1.0.0.201507221040.zip!/,http://download.eclipse.org/releases/mars/' -installIU org.temp.ide.eclipse.main.feature.feature.group -vmargs -Dosgi.requiredJavaVersion=1.7 -Dorg.eclipse.ecf.provider.filetransfer.excludeContributors=org.eclipse.ecf.provider.filetransfer.httpclient4 -Dorg.eclipse.ecf.provider.filetransfer.retrieve.readTimeout=10000 -Dorg.eclipse.ecf.provider.filetransfer.retrieve.retryAttempts=30 -Dorg.eclipse.ecf.provider.filetransfer.retrieve.closeTimeout=10000 -Djava.net.useSystemProxies=true
Installing org.temp.ide.eclipse.main.feature.feature.group 1.0.0.201507221039.
Operation completed in 14243 ms.
linux success:
+ eclipse/eclipse -application org.eclipse.equinox.p2.director -nosplash -consoleLog --launcher.suppressErrors -repository 'jar:file:org.temp.ide.eclipse.feature_1.0.0.201507221040.zip!/,http://download.eclipse.org/releases/mars/' -installIU org.temp.ide.eclipse.main.feature.feature.group -vmargs -Dosgi.requiredJavaVersion=1.7 -Dorg.eclipse.ecf.provider.filetransfer.excludeContributors=org.eclipse.ecf.provider.filetransfer.httpclient4 -Dorg.eclipse.ecf.provider.filetransfer.retrieve.readTimeout=60000 -Dorg.eclipse.ecf.provider.filetransfer.retrieve.retryAttempts=30 -Dorg.eclipse.ecf.provider.filetransfer.retrieve.closeTimeout=60000 -Dorg.eclipse.ecf.provider.filetransfer.browse.connectTimeout=60000 -Dorg.eclipse.ecf.provider.filetransfer.browse.readTimeout=60000 -Djava.net.useSystemProxies=true -Djava.net.preferIPv4Stack=true -Dp2.atomic.composite.loading=true
Operation completed in 21261 ms.
Linux fail:
[Fatal Error] :36729:77: Premature end of file.
!SESSION 2015-07-22 13:50:59.565 -----------------------------------------------
eclipse.buildId=4.4.2.M20150204-1700
java.version=1.8.0_45
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -application org.eclipse.equinox.p2.director -repository jar:file:org.temp.ide.eclipse.feature_1.0.0.201507221040.zip!/,http://download.eclipse.org/releases/mars/ -installIU org.temp.ide.eclipse.main.feature.feature.group
Command-line arguments: -os linux -ws gtk -arch x86_64 -application org.eclipse.equinox.p2.director -consoleLog -repository jar:file:org.temp.ide.eclipse.feature_1.0.0.201507221040.zip!/,http://download.eclipse.org/releases/mars/ -installIU org.temp.ide.eclipse.main.feature.feature.group
!ENTRY org.eclipse.equinox.p2.core 4 0 2015-07-22 13:51:06.534
!MESSAGE Provisioning exception
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://download.eclipse.org/releases/mars/201506241002.
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepositoryIO.read(SimpleArtifactRepositoryIO.java:128)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepositoryFactory.load(SimpleArtifactRepositoryFactory.java:108)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepositoryFactory.load(SimpleArtifactRepositoryFactory.java:76)
at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.factoryLoad(ArtifactRepositoryManager.java:73)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:768)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:668)
at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:104)
at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:100)
at org.eclipse.equinox.internal.p2.artifact.repository.CompositeArtifactRepository.load(CompositeArtifactRepository.java:474)
at org.eclipse.equinox.internal.p2.artifact.repository.CompositeArtifactRepository.addChild(CompositeArtifactRepository.java:172)
at org.eclipse.equinox.internal.p2.artifact.repository.CompositeArtifactRepository.<init>(CompositeArtifactRepository.java:96)
at org.eclipse.equinox.internal.p2.artifact.repository.CompositeArtifactRepositoryFactory.load(CompositeArtifactRepositoryFactory.java:116)
at org.eclipse.equinox.internal.p2.director.app.DirectorApplication.initializeRepositories(DirectorApplication.java:535)
at org.eclipse.equinox.internal.p2.director.app.DirectorApplication.run(DirectorApplication.java:1094)
at org.eclipse.equinox.internal.p2.director.app.DirectorApplication.start(DirectorApplication.java:1281)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Caused by: java.io.IOException: Premature end of file.
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepositoryIO$Parser.parse(SimpleArtifactRepositoryIO.java:316)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepositoryIO.read(SimpleArtifactRepositoryIO.java:101)
... 32 more
!SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 1002 2015-07-22 13:51:06.536
!MESSAGE Unable to read repository at http://download.eclipse.org/releases/mars/201506241002.
!STACK 0
!ENTRY org.eclipse.equinox.p2.artifact.repository 4 1002 2015-07-22 13:51:06.538
!MESSAGE Unable to read repository at http://download.eclipse.org/releases/mars/.
!STACK 1
... 32 more
!SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 1002 2015-07-22 13:51:06.540
!STACK 0
!ENTRY org.eclipse.equinox.p2.core 4 0 2015-07-22 13:51:38.375
!STACK 1
at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedArtifactRepositories(ProvisioningContext.java:160)
at org.eclipse.equinox.p2.engine.ProvisioningContext.getArtifactRepositories(ProvisioningContext.java:143)
at org.eclipse.equinox.internal.p2.engine.DownloadManager.start(DownloadManager.java:91)
at org.eclipse.equinox.internal.p2.engine.phases.Collect.completePhase(Collect.java:104)
at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:251)
at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:101)
at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:47)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:75)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44)
at org.eclipse.equinox.internal.provisional.p2.director.PlanExecutionHelper.executePlan(PlanExecutionHelper.java:41)
at org.eclipse.equinox.internal.provisional.p2.director.PlanExecutionHelper.executePlan(PlanExecutionHelper.java:23)
at org.eclipse.equinox.internal.p2.director.app.DirectorApplication.executePlan(DirectorApplication.java:802)
at org.eclipse.equinox.internal.p2.director.app.DirectorApplication.planAndExecute(DirectorApplication.java:795)
at org.eclipse.equinox.internal.p2.director.app.DirectorApplication.performProvisioningActions(DirectorApplication.java:782)
at org.eclipse.equinox.internal.p2.director.app.DirectorApplication.run(DirectorApplication.java:1099)
... 45 more
!SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 1002 2015-07-22 13:51:38.377
!STACK 0
Installation failed.
An error occurred while collecting items to be installed
session context was:(profile=SDKProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.emf.common,2.11.0.v20150512-0501
No repository found containing: osgi.bundle,org.eclipse.emf.ecore,2.11.0.v20150512-0501
No repository found containing: osgi.bundle,org.eclipse.emf.ecore.change,2.11.0.v20150512-0501
No repository found containing: osgi.bundle,org.eclipse.emf.ecore.xmi,2.11.0.v20150512-0501
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.common,2.11.0.v20150512-0501
No repository found containing: osgi.bundle,org.eclipse.emf.databinding,1.3.0.v20150601-0402
No repository found containing: osgi.bundle,org.eclipse.emf.databinding.edit,1.3.0.v20150601-0402
No repository found containing: org.eclipse.update.feature,org.eclipse.emf.ecore,2.11.0.v20150512-0501
No repository found containing: osgi.bundle,org.eclipse.emf.edit,2.11.0.v20150601-0402
Application failed, log file location:eclipse/configuration/1437562259667.log
!ENTRY org.eclipse.equinox.p2.engine 4 4 2015-07-22 13:51:39.097
!MESSAGE An error occurred while collecting items to be installed
!SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2015-07-22 13:51:39.097
!MESSAGE session context was:(profile=SDKProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
!SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 0 2015-07-22 13:51:39.097
!MESSAGE No repository found containing: osgi.bundle,org.eclipse.emf.common,2.11.0.v20150512-0501
!MESSAGE No repository found containing: osgi.bundle,org.eclipse.emf.ecore,2.11.0.v20150512-0501
!MESSAGE No repository found containing: osgi.bundle,org.eclipse.emf.ecore.change,2.11.0.v20150512-0501
!MESSAGE No repository found containing: osgi.bundle,org.eclipse.emf.ecore.xmi,2.11.0.v20150512-0501
!MESSAGE No repository found containing: org.eclipse.update.feature,org.eclipse.emf.common,2.11.0.v20150512-0501
!MESSAGE No repository found containing: osgi.bundle,org.eclipse.emf.databinding,1.3.0.v20150601-0402
!MESSAGE No repository found containing: osgi.bundle,org.eclipse.emf.databinding.edit,1.3.0.v20150601-0402
!MESSAGE No repository found containing: org.eclipse.update.feature,org.eclipse.emf.ecore,2.11.0.v20150512-0501
!MESSAGE No repository found containing: osgi.bundle,org.eclipse.emf.edit,2.11.0.v20150601-0402
Build step 'Execute shell' marked build as failure
Re: Premature end of file under linux in CLI / not seen under Windows [message #1702976 is a reply to message #1702441] |
Mon, 27 July 2015 12:09  |
Your problem is an illustration of Leslie Lamport's famous quote about distributed computing:
Quote:"A distributed system is one in which the failure of a computer you didn't even know existed can render your own computer unusable." -- Leslie Lamport
In your case, your computer isn't unusable but your tests are inconclusive.
- Your test results are now tied to a service that is out of your control (download.eclipse.org): you can't tell if your failure is because of a local code change (presumably under your control), because of the external network, or because download.eclipse.org is down or misbehaving. Your dependency is further compounded as download.eclipse.org also redirects requests to mirror sites. And it's further compounded as you're assuming 'http://download.eclipse.org/releases/mars' is correct.
- Different network stacks behave differently in the face of network errors. Likely explains the results you're seeing: Linux and Windows have two independently implemented network stacks.
My suggestion: mirror the requisite pieces from download.eclipse.org and run your tests against your local mirror. Your tests should be run in as controlled an environment as possible.
Brian.
Current Time: Sat Jul 19 02:42:41 EDT 2025
Powered by FUDForum. Page generated in 0.03178 seconds
