[Texo] Annotation of EReference with no cascades [message #1699432] |
Wed, 24 June 2015 05:52  |
I want to annotate an EReference such that no cascades are generated.
I have a class with a reference to itself. When an instance refers to itself (via some other instance), this results in an exception when merge() on the same instance is applied twice.
This happens because the generated JPA code for the class has the cascade.merge (amongst others) annotation for the EReference.
So, I want to remove this JPA annotation, preferably by an texo annotation model.
Here is what I did:
in the annotation model:
- added annotation for the EReference
- added an ORM annotation
- added a many-to-many annotation
- added cascade type annotation
- added empty type cascade annotation
However the annotation editor returns then with following error:
An error has occurred. See error log for more details.
The string resource '_UI_cascadeDetach' could not be located
The resulting annotation looks as follows:
<eReferenceAnnotations xsi:type="ormannotations:EReferenceORMAnnotation">
<manyToMany>
<cascade>
<cascadeDetach/>
</cascade>
</manyToMany>
</eReferenceAnnotations>
Generation of JPA classes also results in an error.
Help is appreciated.
Cur
Re: [Texo] Annotation of EReference with no cascades [message #1702867 is a reply to message #1699432] |
Sun, 26 July 2015 19:07   |
Hi Cur,
Hmm I missed your post. In any case I published a new build just now which should solve this problem. Let me know if it
stills occurs.
gr. Martin
On 24-06-15 11:52, Mr Cur wrote:
> EReference.
> Here is what I did:
> <manyToMany>
> <cascade>
> <cascadeDetach/>
> </cascade>
> </manyToMany>
> Cur
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] Annotation of EReference with no cascades [message #1703607 is a reply to message #1703139] |
Mon, 03 August 2015 11:07  |
Hi Cur,
A mistake, I published a new build which solves this. The detach cascade type was not handled correctly. I solved this
also. If you don't want cascade you should create a cascadetype node without cascades inside it.
gr. Martin
On 28-07-15 22:10, Mr Cur wrote:
> Hi Martin,
> Thanks for the update.
> I experience still a problem with the code generation.
> With the following annotation for a bi-directional JPA relation:
> <manyToMany mappedBy="myrelation">
> <cascade>
> <cascadeDetach/>
> </cascade>
> </manyToMany>
> the following code is generated:
> @javax.persistence.ManyToMany(, mappedBy="myrelation")
> which does not compile (due to the ',');
> Btw: the inverse relation (with no mappedBy annotion) generates:
> @javax.persistence.ManyToMany()
> which seems to be ok.
> Thanks.
> -- Cur
The Netherlands
FUDForum. Page generated in 0.05606 seconds
