Home » Modeling » GMF (Graphical Modeling Framework) » Having customized forms or Adding Menus/Toolbars/Context Menus and etc. when running GMF as a plugin
Re: Having customized forms or Adding Menus/Toolbars/Context Menus and etc. when running GMF as a pl [message #1702559 is a reply to message #1702105] |
Thu, 23 July 2015 04:37   |
Hi Parsa Pourali,
Shhhhhh... this is a TOP SECRET....
Go to your *.diagram plug-in, go to the package xxxxx.diagram.part, and go to the Java Class DiagramEditorContextMenuProvider.java. In this class, go to the buildContextMenu() function and check how works the next code :
menu.remove(ActionIds.ACTION_DELETE_FROM_MODEL);
menu.appendToGroup("editGroup", deleteAction);
In this point you have access to the Context Menu, from all point of your Diagram Editor Surface... Study how add new actions and Menus some code to study, and decide what actions and submenus do you have include in your Context Menu...
[Updated on: Thu, 23 July 2015 07:01] by Moderator
Re: Having customized forms or Adding Menus/Toolbars/Context Menus and etc. when running GMF as a pl [message #1703888 is a reply to message #1703695] |
Wed, 05 August 2015 11:54   |
Hi Aurelien,
Thank you so much, the link was a very good starting point for me, it was very helpful.
Also, it may be a long shot, but I'd rather ask, do you know or think that we can have access to the elements of a model. for example, I want to have an action listener on the transition label of a state diagram. So, whenever the user tries to edit the label of a transition in a state machine, I can listen to it and do some code ... not sure , if it is possible in GMF or other modelling frameworks ...
Parsa
Current Time: Mon Jul 21 07:28:47 EDT 2025
Powered by FUDForum. Page generated in 0.28867 seconds
