Home » Eclipse Projects » Nebula » Column Name Can be Rename In NatTable(The Column Name in the natTable can be renamed)
Column Name Can be Rename In NatTable [message #1702313] Tue, 21 July 2015 09:45 Go to next message
Is it possible to rename the column names of the nat table at runtime.
if it is possible how.
It would be better if suggested with some example.
Thanks you
Shashi
Re: Column Name Can be Rename In NatTable [message #1702316 is a reply to message #1702313] Tue, 21 July 2015 09:57 Go to previous messageGo to next message
Please ask questions related to NatTable in the NatTable forum.
https://www.eclipse.org/forums/index.php/f/240/
Regarding your question, you need to be more precise. Should a user be able to change the column name at runtime or do you want to change it programmatically. For the programmatical way, simply use an IDataProvider for the column header that supports that. For the user, you need to register a column header menu with a renameColumnMenuItemProvider.
Re: Column Name Can be Rename In NatTable [message #1702319 is a reply to message #1702316] Tue, 21 July 2015 10:03 Go to previous message
Oh, and there are lots of examples in the NatTable examples application, e.g. Tutorial Examples -> Data -> DynamicColumnExample adds the HeaderMenuConfiguration, which by default has the menu item configured for opening the column rename dialog.
natTable.addConfiguration(new HeaderMenuConfiguration(natTable));
Previous Topic:Tab key navigation in the grid.
Next Topic:Nebula grid widget - change header height
Current Time: Fri Oct 03 23:08:25 EDT 2025
Powered by FUDForum. Page generated in 0.03670 seconds
