Merge referenced pseudo conflicts results in defect model [message #1702191] |
Mon, 20 July 2015 10:22  |
I tried to merge two files with ancestor, where a new element was added on both sides:
Ancestor is empty.
Right has new EObjects:
Wheel (size: 2'')
Vehicle (name: car) -> Wheel
Left has new EObjects:
Wheel (size: 2'')
Vehicle (name:truck) -> Wheel
Leads to pseudo conflict because of the new wheels and a the vehicle changes. After merging the car to the left, the truck has no wheel anymore. I have a more complex scenario, where the wheel has also some eOpposite references which shows, that the wheel is removed on the left while merging. And added from the right again.
Is this the designed behavior of pseudo conflicting merges? I would expect no changes for wheel both vehicles referencing the same instance afterwards.
Benjamin
Re: Merge referenced pseudo conflicts results in defect model [message #1702596 is a reply to message #1702564] |
Thu, 23 July 2015 09:02  |
Hi Laurent,
thanks for your answer. I tried to reproduce it with ecore files and failed. It must depent somehow on matches, diffs and dependencies in my model. If both attributes in ecore have the same name, the attribute is matched and let to a real conflict.
I will investigate and write again, if I know more details.
Benjamin
FUDForum. Page generated in 0.04507 seconds
