Home » Newcomers » Newcomers » Eclipse JEE 4.5.0 (MARS)(How to install Eclipse JEE 4.5.0 (Need Install instructions))
Eclipse JEE 4.5.0 (MARS) [message #1701924] Thu, 16 July 2015 13:29 Go to next message
I installed JDK 32 bit 1.7.0_60 on my machine and unzipped eclipse 4.5.0 mars to my C:\program files x(86). I get a error message when i rum the eclipse.exe.
Below is the error message:
version 1.60_95 of the jvm is not suitable for this product . version 1.7 or greater is required
I set the environment variable to point 32 bit JDK
Please help me out on this issue.
thanks,
Karthick.
Re: Eclipse JEE 4.5.0 (MARS) [message #1701932 is a reply to message #1701924] Thu, 16 July 2015 15:45 Go to previous messageGo to next message
karthick Balaiah wrote on Thu, 16 July 2015 13:29
Which one? PATH? Have you tried pointing Eclipse at the correct java.exe using the command line -vm switch?
Re: Eclipse JEE 4.5.0 (MARS) [message #1701989 is a reply to message #1701932] Fri, 17 July 2015 05:42 Go to previous messageGo to next message
I created user variable PATH = C:\WINDOWS;C:\WINDOWS\system32;C:\Program Files (x86)\Java\jdk1.7.0_60\bin
System variable JAVA_HOME = C:\Program Files (x86)\Java\jdk1.7.0_60 and ran the executable file.
'Have you tried pointing Eclipse at the correct java.exe using the command line -vm switch?'
How to make -vm switch point the correct JVM?
Re: Eclipse JEE 4.5.0 (MARS) [message #1701998 is a reply to message #1701989] Fri, 17 July 2015 06:30 Go to previous messageGo to next message
Am 17.07.2015 um 11:42 schrieb karthick Balaiah:
The new Eclipse Installer would configure that automatically for you: http://wiki.eclipse.org/Eclipse_Installer
Cheers
/Eike
http://www.esc-net.de
Re: Eclipse JEE 4.5.0 (MARS) [message #1702019 is a reply to message #1701998] Fri, 17 July 2015 10:11 Go to previous messageGo to next message
I would like to understand the manual process.
Can you please help?
Re: Eclipse JEE 4.5.0 (MARS) [message #1702021 is a reply to message #1702019] Fri, 17 July 2015 11:13 Go to previous messageGo to next message
I need to completed this as soon as possible.
please help me out.
Re: Eclipse JEE 4.5.0 (MARS) [message #1702041 is a reply to message #1702021] Fri, 17 July 2015 16:29 Go to previous message
You should read all of the Announcement messages at the top of the Newcomers forum, specifically the one titled Eclipse won't start? READ THIS FIRST...
Previous Topic:Luna Project Explorer shows folder as unknown type
Next Topic:Phortran outline links don't work
Current Time: Wed Jun 04 15:57:43 EDT 2025
Powered by FUDForum. Page generated in 0.09024 seconds
