Home » Eclipse Projects » RCP Testing Tool » Super group context does not match group context values properly
Super group context does not match group context values properly [message #1701495] Mon, 13 July 2015 13:20 Go to next message
I am using a Super group context and two group context in it.
1) It only appears 1 runs when I understand that should appears 2 runs. Once by each group context.
2) There is a error matching. It takes one context of one group and one context of the other tu run the test.
If I run the super group with one group context, it runs correctly. It looks like a bug.
[Updated on: Mon, 13 July 2015 13:20] by Moderator
Re: Super group context does not match group context values properly [message #1701497 is a reply to message #1701495] Mon, 13 July 2015 13:40 Go to previous messageGo to next message
Item 2 is solved. I have check the clean preferences and they correct good.
I still have the problem related to amount of runnings.
[Updated on: Mon, 13 July 2015 13:40] by Moderator
Re: Super group context does not match group context values properly [message #1701500 is a reply to message #1701497] Mon, 13 July 2015 14:07 Go to previous messageGo to next message
It's solved. I have made a mistake when creating the super group context.
Re: Super group context does not match group context values properly [message #1701988 is a reply to message #1701500] Fri, 17 July 2015 05:35 Go to previous message
Hi Agustin,
Happy to hear it!
Kind regards,
Ulyana.
Previous Topic:How to Calculate the duration of a command
Next Topic:Problem when trying to handle a browser
Current Time: Mon Jul 21 01:01:27 EDT 2025
Powered by FUDForum. Page generated in 0.05636 seconds
