Home » Language IDEs » C / C++ IDE (CDT) » 'headless' CDT?
'headless' CDT? [message #169996] Fri, 19 May 2006 13:00 Go to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
I've seen a few comments in this, and other newsgroups, referring to a
'headless' Eclipse/CDT. I assume this means Eclipse without the GUI,
and I think the context was to build projects in a batch mode.
1. Is this correct
2. How do I use it?
Derek
Re: 'headless' CDT? [message #170122 is a reply to message #169996] Sun, 21 May 2006 16:18 Go to previous messageGo to next message
Originally posted by: eclipse.kfdd.mine.nu
Isn't it just to invoke 'make'?
Straight forward for standard make projects.
For managed make, you need to invoke make from the configuration
subdirectory, e.g. "Debug".
> 1. Is this correct
> 2. How do I use it?
Re: 'headless' CDT? [message #170143 is a reply to message #170122] Mon, 22 May 2006 07:12 Go to previous messageGo to next message
It's not quite that simple. If you have a 'clean' project (for example,
checked stuff out of CVS), then the Debug directory doesn't exist. You
need Eclipse to generate the Debug/Release directory and make files first...
Derek
>> 1. Is this correct
>> 2. How do I use it?
>> Thanks,
Re: 'headless' CDT? [message #170182 is a reply to message #170143] Tue, 23 May 2006 05:41 Go to previous message
Hi Derek,
it is in fact possible to extend eclipse so that it will run a different
application than a workbench. There is, for example, an entry point to build
plug-ins in headless mode.
There is however no application entry point to run C/C++ builds - until you
make one :-)
Norbert Ploett
Previous Topic:Problem with linker options "-l"
Next Topic:Is there a interface for text-based search in the project?
Current Time: Sat Nov 08 23:25:55 EST 2025
Powered by FUDForum. Page generated in 0.05620 seconds
