Home » Modeling » EMF Parsley » Use getDisplayName() of PropertyDescriptors to get display names of features
Use getDisplayName() of PropertyDescriptors to get display names of features [message #1701546] Tue, 14 July 2015 02:04 Go to next message
if no label providers are specified, Parsley uses the ItemLabelProvider in the *.edit-plugin to resolve the display names of classes. However, it does not use the property descriptors to resolve the display names of features. Instead, the feature name itself is displayed. Is there a specific reason for this behavior? How can I implement a FeatureCaptionProvider that delegates to the appropriate property descriptor of the feature? The problem I'm currently facing is that the ItemProviderAdapterFactory needs an instance of the class to which the feature belongs in order to return the property descriptor. However, the method defaultText() of FeatureCaptionProvider only gets the EStructuralFeature itself. Creating a dummy instance of the class would be a possibility but that does not work for concrete classes. Is there another way to get the instance EObject, e.g. via DI?
Stephan
Re: Use getDisplayName() of PropertyDescriptors to get display names of features [message #1701699 is a reply to message #1701546] Wed, 15 July 2015 02:36 Go to previous messageGo to next message
On 14/07/2015 15:04, Stephan Hildebrandt wrote:
Hi Stephan
see comments below
I guess this can be considered a bug; could you please file a bug?
If you have an EStructuralFeature you can use getEContainingClass,
http://download.eclipse.org/modeling/emf/emf/javadoc/2.11/org/eclipse/emf/ecore/EStructuralFeature.html#getEContainingClass(),
to retrieve its class.
Does that temporarily fix your problem?
cheers
Lorenzo
> Best regards,
> Stephan
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Use getDisplayName() of PropertyDescriptors to get display names of features [message #1701702 is a reply to message #1701699] Wed, 15 July 2015 02:54 Go to previous messageGo to next message
Hi Lorenzo,
I'll file a bug.
No, that does not solve the problem. The problem is not getting the EClass that contains the feature. The problem is getting the instance whose properties are displayed in the end. The method defaultText() only gets the feature but the property descriptor needs the instance as well.
Stephan
Re: Use getDisplayName() of PropertyDescriptors to get display names of features [message #1701703 is a reply to message #1701702] Wed, 15 July 2015 03:06 Go to previous messageGo to next message
On 15/07/2015 08:54, Stephan Hildebrandt wrote:
> Hi Lorenzo,
> I'll file a bug.
If ItemProviderAdapterFactory needs an instance (EObject) then I
remember why we don't delegate to it by default: the
FeatureCaptionProvider is used also in contexts where there's no
instance yet, e.g., for the headers of the columns of the table. In the
form, instead, the EObject is actually available (I guess this is your
context, isn't it?). So we can think of enriching the API so that when
an EObject is available then we delegate to ItemProviderAdapterFactory,
and, in general, the EObject is passed to defaultText as well.
what do you think?
cheers
Lorenzo
Xtext Book:
Re: Use getDisplayName() of PropertyDescriptors to get display names of features [message #1701704 is a reply to message #1701703] Wed, 15 July 2015 03:16 Go to previous messageGo to next message
Hi Lorenzo,
> Hi
Yes, exactly. I think, this is the common case.
> what do you think?
> cheers
> Lorenzo
That sounds good.
Stephan
Re: Use getDisplayName() of PropertyDescriptors to get display names of features [message #1701714 is a reply to message #1701704] Wed, 15 July 2015 04:19 Go to previous messageGo to next message
On 15/07/2015 09:16, Stephan Hildebrandt wrote:
> Hi Lorenzo,
>> Hi
>> what do you think?
>> cheers
>> Lorenzo
> That sounds good.
Hi Stephan
In the meantime I had a look at the library example edit plugin, and I
see that getPropertyDescriptors(Object object) takes an Object, but then
it does not use it all. To be honest I think it makes sense NOT to use
the instance to build descriptions of features, since such descriptions
usually do not depend on the properties of the object itself... even if
you want to build a property description based on some state of the
object, as soon as you modify the object you should also modify its
property description, which I think is not considered at all in EMF.
Is using the object itself a requirement in your case, or do you need it
only to use the ItemProviderAdapterFactory? If you don't need the state
of the object and you simply want to use the edit plugin I think you can
simply pass null. Could you please try that? I'm assuming you already
have access to the ItemProviderAdapterFactory.
In the meantime we'll work on using it also on Parsley as a default
case, possibly considering also the case when an EObject is effectively
available.
cheers
Lorenzo
Xtext Book:
Re: Use getDisplayName() of PropertyDescriptors to get display names of features [message #1701740 is a reply to message #1701714] Wed, 15 July 2015 06:33 Go to previous messageGo to next message
Hi Lorenzo,
I need the instance to get the property descriptor from the ItemProviderAdapterFactory like this
((IItemPropertySource) adapterFactory.adapt(instance, IItemPropertySource.class).getPropertyDescriptor(instance, feature)
You are right that getPropertyDescriptor does not use the instance parameter in most cases but it is required in order to get the IItemPropertySource. I don't know of any other way to get the property descriptors. Usually, you only have the AdapterFactory available in an editor.
Stephan
Re: Use getDisplayName() of PropertyDescriptors to get display names of features [message #1701744 is a reply to message #1701740] Wed, 15 July 2015 06:58 Go to previous messageGo to next message
On 15/07/2015 12:33, Stephan Hildebrandt wrote:
> Hi Lorenzo,
> editor.
OK, I see.
By the way, you also tried creating an instance with the EClass and it
did not work?
cheers
Lorenzo
Xtext Book:
Re: Use getDisplayName() of PropertyDescriptors to get display names of features [message #1701747 is a reply to message #1701744] Wed, 15 July 2015 07:10 Go to previous messageGo to next message
Yes, I did. But that does not work for abstract classes. For abstract classes, I would need to search for a concrete subclass and instantiate it. But that is not that simple (and it does not seem to be elegant) because an EClass has only references to its superclasses, not its subclasses. I would need to examine all classes in the package and search for a subclass of the abstract class. However, subclasses may be (and in my case, are) spread among several packages. In fact, in my case, the abstract base classes are contained in a separate package that does not contain any concrete classes. So the search space becomes very large and the whole approach infeasible.
Stephan
Re: Use getDisplayName() of PropertyDescriptors to get display names of features [message #1708617 is a reply to message #1701747] Fri, 18 September 2015 02:52 Go to previous message
> Best regards,
> Stephan
the problem is fixed in the new release 0.5.0 which is already
available, please have a look at the updated documentation (and
migration guide).
cheers
Lorenzo
Xtext Book:
Previous Topic:Context menu in SelectionTreeView
Next Topic:TreeTable
Current Time: Sun Jul 20 23:25:31 EDT 2025
Powered by FUDForum. Page generated in 0.07781 seconds
