Home » Eclipse Projects » Sirius » Different options to specify label position around border node
Different options to specify label position around border node [message #1701606] |
Tue, 14 July 2015 07:51  |
I was wondering if there are further options than the ones provided in the "Label" tab of a "Style" Mapping element on viewpoint specification level.
See this screenshot:
Here it seems like there is only the possibility to set the "Label Position" to "border" or "node", but nothing like left, right, top, bottom.
I am looking for options that for example an end user has who is working with such a diagram. For example:
- Position a label on top, right, left, under a border node
Here the label "BorderNode1" is in the default position and the label "BorderNode2" was moved to the left hand side of the border node manually.
Benjamin.
Re: Different options to specify label position around border node [message #1701773 is a reply to message #1701606] |
Wed, 15 July 2015 09:59   |
Indeed currently you are not able to specify the label position in the
GMF. You will have to follow the documentation about how to provide a
custom style [1].
Note that in your case the customization will be quite light. First you
will need to add an extension point on
"org.eclipse.sirius.diagram.ui.styleConfigurationProvider" to provide
your own "IStyleConfigurationProvider".
In your class implementing IStyleConfigurationProvider, implement
"provides", to return true for your mapping, and
"createStyleConfiguration" to return your own SimpleStyleConfiguration
for your mapping.
In your class extending SimpleStyleConfiguration, override
getNameBorderItemLocator to return a BorderItemLocator set on your
prefered side.
Example for a label always located on the west border:
public IBorderItemLocator getNameBorderItemLocator(DNode node,
IFigure mainFigure) {
BorderItemLocator locator = new BorderItemLocator(mainFigure,
PositionConstants.WEST);
return locator;
Steve
Le 14/07/2015 13:51, Benjamin Esterl a écrit :
> Hello,
> Regards,
> Benjamin.
Steve Monnier - Obeo
Need professional services for Sirius?
Re: Different options to specify label position around border node [message #1703183 is a reply to message #1701773] |
Wed, 29 July 2015 03:39  |
I noticed that I forgot the link to the documentation in my previous answer.
[1]
https://www.eclipse.org/sirius/doc/developer/extensions-provide_custom_style.html
Steve
Le 15/07/2015 15:59, Steve Monnier a écrit :
> Hello,
> custom style [1].
> for your mapping.
> prefered side.
> BorderItemLocator(mainFigure, PositionConstants.WEST);
> return locator;
> Regards,
> Steve
>> Hello,
>> bottom.
>> manually.
>> Regards,
>> Benjamin.
Current Time: Fri Jul 25 17:31:33 EDT 2025
Powered by FUDForum. Page generated in 0.04795 seconds
