Home » Language IDEs » ServerTools (WTP) » NoClassDefFoundError: org/eclipse/wst/common/componentcore/GlobalComponentChangeListener
NoClassDefFoundError: org/eclipse/wst/common/componentcore/GlobalComponentChangeListener [message #170128] Thu, 25 May 2006 10:17 Go to next message
Originally posted by: dserodio.gmail.com
I'm using the latest WTP 1.5RC available on Callisto Discovery Site
(Version: 1.5.0.v200604030005-eYe38P_OHPq8Dcd, Build id: 200604210753),
and when I click on Project Preferences > J2EE Module Dependencies, a
"The currently displayed page contains invalid values" dialog.
Anyone seen this error? The error log shows:
!ENTRY org.eclipse.jface 4 2 2006-05-25 11:15:55.953
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
java.lang.NoClassDefFoundError:
org/eclipse/wst/common/componentcore/GlobalComponentChangeLi stener
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:160)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:498)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:468)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:427)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:410)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:339)
at
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:388)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:352)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at
org.eclipse.jst.j2ee.internal.JARDependencyPropertiesPage.<init >(JARDependencyPropertiesPage.java:107)
at
org.eclipse.jst.j2ee.internal.WebLibDependencyPropertiesPage . <init>(WebLibDependencyPropertiesPage.java:51)
at
org.eclipse.jst.j2ee.internal.J2EEDependenciesPage.createWeb Content(J2EEDependenciesPage.java:110)
at
org.eclipse.jst.j2ee.internal.J2EEDependenciesPage.createCon tents(J2EEDependenciesPage.java:73)
at
org.eclipse.jface.preference.PreferencePage.createControl(Pr eferencePage.java:233)
at
org.eclipse.jface.preference.PreferenceDialog.createPageCont rol(PreferenceDialog.java:1403)
at
org.eclipse.jface.preference.PreferenceDialog$12.run(Prefere nceDialog.java:1162)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
at
org.eclipse.jface.preference.PreferenceDialog.showPage(Prefe renceDialog.java:1156)
at
org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.sho wPage(FilteredPreferenceDialog.java:439)
at
org.eclipse.jface.preference.PreferenceDialog$8.selectionCha nged(PreferenceDialog.java:661)
at
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:839)
at
org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:837)
at
org.eclipse.jface.viewers.StructuredViewer.handlePostSelect( StructuredViewer.java:1143)
at
org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected( StructuredViewer.java:1163)
at
org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(O penStrategy.java:236)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:230)
at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java: 404)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at
org.eclipse.ui.dialogs.PropertyDialogAction.run(PropertyDial ogAction.java:156)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
at
org.eclipse.ui.actions.RetargetAction.runWithEvent(RetargetA ction.java:229)
at org.eclipse.jface.commands.ActionHandler.execute(ActionHandl er.java:119)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:461)
at
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:424)
at
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:160)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchKeyboard.java:466)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.java:799)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(WorkbenchKeyboard.java:846)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(WorkbenchKeyboard.java:564)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(Work benchKeyboard.java:506)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter .handleEvent(WorkbenchKeyboard.java:122)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:982 )
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:927)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:952)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:937)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:965)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:961)
at org.eclipse.swt.widgets.Widget.wmSysChar(Widget.java:2176)
at org.eclipse.swt.widgets.Control.WM_SYSCHAR(Control.java:3886 )
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3318 )
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:4768)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4025 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:19 23)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2966)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
TIA,
Daniel Serodio
Re: NoClassDefFoundError: org/eclipse/wst/common/componentcore/GlobalComponentChangeListener [message #170246 is a reply to message #170128] Fri, 26 May 2006 13:08 Go to previous message
Hi Daniel,
Certainly looks like an issue with the tools. Can you open a bug report
with the information you posted here?
https://bugs.eclipse.org/bugs -> Report new -> WebTools -> Web Tools ->
wst.common
Lawrence
Previous Topic:WSDL Editor question
Next Topic:WTP/TPTP Developing and Profiling Web Services Webinar June 12
Current Time: Wed Jul 23 23:06:42 EDT 2025
Powered by FUDForum. Page generated in 0.04198 seconds
