Problem starting Eclipse Mars, " [message #1700887] |
Tue, 07 July 2015 17:03  |
I have been running Eclipse Kepler on a very large C/C++ project for a few years. Recently, I have experienced a drastic slow-down in the UI, which I have not been able to resolve. So, I have decided to upgrade to the latest version of Eclipse in order to see if that will fix my problem. Unfortunately, I have encountered several problems with the newer version of Eclipse.
I am running Eclipse Mars on CentOS 6.6. I have downloaded it from Eclipse, not using an RPM or other package for my OS. I also downloaded Oracle's JRE 1.8.0.45, and configured the eclipse.ini to use that version of Java. Finally, I have pointed Eclipse to my existing Kepler workspace in order to retain all of that precious information.
When Eclipse starts up, it displays my existing workspace, and also an error message:
'Setup check' has encountered a problem.
An internal error occurred during: "Setup check".
The details state:
Opening the error log view shows a ton of messages like this, all of which relate to some GIF file or other:
eclipse.buildId=4.5.0.I20150603-2000
java.version=1.8.0_45
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.cpp.product
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.cpp.product
This is a continuation of log file /swdev/.metadata/.bak_0.log
Created Time: 2015-07-07 16:54:13.613
org.eclipse.core.runtime
Error
Tue Jul 07 16:54:13 EDT 2015
Invalid input url:platform:/plugin/org.eclipse.jdt.ui/icons/full/eview16/types.gif
java.io.IOException: Unable to resolve plug-in "platform:/plugin/org.eclipse.jdt.ui/icons/full/eview16/types.gif".
at org.eclipse.core.internal.runtime.PlatformURLPluginConnection.parse(PlatformURLPluginConnection.java:65)
at org.eclipse.core.internal.runtime.FindSupport.find(FindSupport.java:290)
at org.eclipse.core.runtime.FileLocator.find(FileLocator.java:152)
at org.eclipse.jface.resource.URLImageDescriptor.getStream(URLImageDescriptor.java:140)
at org.eclipse.jface.resource.URLImageDescriptor.getImageData(URLImageDescriptor.java:105)
at org.eclipse.jface.resource.URLImageDescriptor.getImageData(URLImageDescriptor.java:100)
at org.eclipse.jface.resource.ImageDescriptor.createImage(ImageDescriptor.java:270)
at org.eclipse.jface.resource.URLImageDescriptor.createImage(URLImageDescriptor.java:291)
at org.eclipse.jface.resource.ImageDescriptor.createImage(ImageDescriptor.java:224)
at org.eclipse.jface.resource.ImageDescriptor.createImage(ImageDescriptor.java:202)
at org.eclipse.ui.internal.dialogs.ViewLabelProvider.getImage(ViewLabelProvider.java:93)
at org.eclipse.jface.viewers.ColumnLabelProvider.update(ColumnLabelProvider.java:35)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn.java:154)
at org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(AbstractTreeViewer.java:949)
at org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeRunnable.run(AbstractTreeViewer.java:114)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:173)
at org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(AbstractTreeViewer.java:1029)
at org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRunnable.run(StructuredViewer.java:473)
at org.eclipse.jface.viewers.StructuredViewer.updateItem(StructuredViewer.java:2176)
at org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem(AbstractTreeViewer.java:843)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer.java:818)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:791)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:611)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:762)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalSetExpanded(AbstractTreeViewer.java:2047)
at org.eclipse.jface.viewers.AbstractTreeViewer.setExpandedElements(AbstractTreeViewer.java:2429)
at org.eclipse.ui.internal.dialogs.ShowViewDialog.restoreWidgetValues(ShowViewDialog.java:338)
at org.eclipse.ui.internal.dialogs.ShowViewDialog.createDialogArea(ShowViewDialog.java:177)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java:768)
at org.eclipse.jface.window.Window.create(Window.java:430)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1096)
at org.eclipse.jface.window.Window.open(Window.java:792)
at org.eclipse.ui.handlers.ShowViewHandler.openOther(ShowViewHandler.java:94)
at org.eclipse.ui.handlers.ShowViewHandler.execute(ShowViewHandler.java:75)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:295)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:252)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:234)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:493)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:486)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:343)
at org.eclipse.ui.internal.ShowViewMenu$3.run(ShowViewMenu.java:147)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:473)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:595)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:511)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:420)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4481)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1327)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3819)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3430)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:654)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:598)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
Any assistance would be greatly appreciated.
FUDForum. Page generated in 0.09189 seconds
