Column Grouping for Tree Grid [message #1700675] |
Mon, 06 July 2015 08:03  |
Hi All,
I am using Tree to display my values . I need to group few columns in the similar way that we have in the NAT tables.. I tried using the same way I did for table for tree ,but my column grouping are not displayed at all.
I am using the below code to create my column header layer,
public ILayer createColumnHeaderLayer()
final ColumnGroupModel columnGroupModel = new ColumnGroupModel();
columnHeaderDataLayer = new DefaultColumnHeaderDataLayer(columnHeaderDataProvider);
columnHeaderLayer = new ColumnHeaderLayer(columnHeaderDataLayer, treeLayer, treeLayer.getSelectionLayer());
ColumnGroupHeaderLayer columnGroupHeaderLayer = new ColumnGroupHeaderLayer(columnHeaderLayer, treeLayer.getSelectionLayer(), columnGroupModel);
columnGroupHeaderLayer.addColumnsIndexesToGroup("Column Group 1",3,4,5,6,7,8);
ColumnGroupHeaderLayer toolcolumnGroupHeaderLayer = new ColumnGroupHeaderLayer(columnHeaderLayer, treeLayer.getSelectionLayer(), columnGroupModel);
toolcolumnGroupHeaderLayer.addColumnsIndexesToGroup("Column Group 2",9,10,11,12,13,14);
columnGroupHeaderLayer.setRowHeight(25);
columnHeaderDataLayer.setColumnWidthByPosition(3, 10);
columnHeaderDataLayer.setColumnWidthPercentageByPosition(0, 80);
columnHeaderDataLayer.setDefaultColumnWidth(200);
columnHeaderDataLayer.setDefaultColumnWidthByPosition(0, 1000);
return columnGroupHeaderLayer;
Is there a issue with the above code ?
Are column groupings supported in tree?
Can you provide me a sample ?
Thanks in Advance.
Re: Column Grouping for Tree Grid [message #1700783 is a reply to message #1700675] |
Tue, 07 July 2015 03:39  |
Quote:Is there a issue with the above code ?
Not at first sight. I'm not sure why there are two GolumnGroupHeaderLayer and it setting the row height has an impact.
Quote:Are column groupings supported in tree?
Sure, why shouldn't it? The column header has no impact on the body, and the tree rendering is part of the body.
Quote:Can you provide me a sample ?
NatTable Examples -> Tutorial Examples -> Integration -> SortableGroupByFilterColumnGroupAndFreezeExample
FUDForum. Page generated in 0.27665 seconds
