Home » Language IDEs » Java Development Tools (JDT) » Unable to Run Database App(Error: 998 is not a valid line number in com.mysql.jdbc.SQLError)
Unable to Run Database App [message #1700760] Mon, 06 July 2015 16:20
I'm in the process of teaching myself how to write data driven apps in Java, but I've run into a bit of a snag. When I try to run my code, I get the following error:
"998 is not a valid line number in com.mysql.jdbc.SQLError"
The following is the code I wrote:
package net.xtraordinayr.mysqldemo;
import java.sql.*;
public class DemoDriver {
		try{
			// Load the driver
			Class.forName("com.mysql.jdbc.Driver");
			// 1. Get a connection to the database
			Connection mySqlConn =
					DriverManager.getConnection("jdbc:mysql://localhost:3306/starfleetacademydb", "root", "ncc_1701-f");
			// 2. Create a statement
			Statement demoQuery = mySqlConn.createStatement();
			// 3. Execute SQL query
			ResultSet mySqlRs = demoQuery.executeQuery("SELECT * FROM student_table");
			// 4. Process the result set
			System.out.println(mySqlRs.getString("rankID") + " " +
					mySqlRs.getString("lastName") + " " +
					mySqlRs.getString("firstName"));
		catch(Exception ex){
			ex.printStackTrace();
Is there any way to get past this issue so that I can determine if my code is working?
TekknoDraykko
Previous Topic:[Eclipse Juno] Problem with set up of JDK8
Next Topic:Wrong IJavaProject returned
Current Time: Sat Jun 07 06:03:26 EDT 2025
Powered by FUDForum. Page generated in 0.02788 seconds
