Home » Eclipse Projects » Oomph » Passing VM args from the self extracting archive to eclipse-inst.exe
Passing VM args from the self extracting archive to eclipse-inst.exe [message #1700564] Fri, 03 July 2015 14:07 Go to next message
If I try
eclipse-inst.exe -vmargs "-Doomph.redirection.setups=http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/->mysetupurl"
it works correctly, but if I try the same against the self extracting exe,
eclipse-inst-win64.exe -vmargs "-Doomph.redirection.setups=http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/->mysetupurl"
it doesn't seem to work.
The self extracting exe doesn't seem to be passing the vmargs to the extracted exe.
Is there a way to get this working without having to extract the archive?
Re: Passing VM args from the self extracting archive to eclipse-inst.exe [message #1700719 is a reply to message #1700564] Mon, 06 July 2015 11:53 Go to previous messageGo to next message
No, it definitely doesn't pass them on. In fact I'm not sure it even
looks at any command line arguments at all...
On 06/07/2015 5:27 PM, Coder Plus wrote:
> If I try
> exe,
> extracted exe.
Re: Passing VM args from the self extracting archive to eclipse-inst.exe [message #1700735 is a reply to message #1700719] Mon, 06 July 2015 13:47 Go to previous message
Am 06.07.2015 um 17:53 schrieb Ed Merks:
Correct. We could investigate that as a new functionality (please submit a bugzilla to remind us) but so far we expected
all "advanced" things to be done only with a "kept" installer. Have you noticed that the installer aks you if you want
to keep it in a permanent (unzipped) location if you switch to advanced mode (or at the end of an installation in simple
mode)?
> In fact I'm not sure it even looks at any command line arguments at all...
IIRC. there's only one "internal" argument recognized that we use to test the fall-back strategy for the case that no
adequate JVM is found.
Cheers
/Eike
http://www.esc-net.de
Previous Topic:Where are the supported annotations documented?
Next Topic:git clone location
Current Time: Sat Jul 19 01:04:40 EDT 2025
Powered by FUDForum. Page generated in 0.06756 seconds
