Home » Modeling » OCL » OCLinEcore: Custom validation messages not working
OCLinEcore: Custom validation messages not working [message #1700726] Mon, 06 July 2015 12:48 Go to next message
Hi all,
I am currently trying to realize custom OCL validation messages by means of the 'OCLinEcoreTutorial' but so far have not been successful. I have performed the following steps:
  1. Set the following OCL preferences
    • Executor targeted by the default OCL delegate: ".../Pivot"
    • Realisation of OCL embedded within Ecore models: "Generate Java Code in *Impl classes"
  2. Create the OCLinEcoreTutorial example
  3. Open the 'Tutorial.ecore' with the OCLinEcore editor
  4. Change the 'SufficientCopies' invariant of the 'Books' class as described here
  5. Generate the model code by means of the genmodel
  6. Make the generated 'TutorialValidator' extend the 'OCLinEcoreEObjectValidator'
  7. Run the generated model code
  8. Create a new model and validate it (with the 'Sample Reflective Ecore Model Editor')
When I validate the model, I always get the default error message (The 'SufficientCopies' constraint is violated ...) instead of the custom error message.
Did I miss anything or does this seem to be a bug? I tried to debug this myself and found that the correct error message seems to be assembled inside the 'SufficientCopies(...)' method of class 'BookImpl'. It is stored in a variable called 'TupleValue'. However, this does not seem to be passed to 'CGStringLogDiagnosticOperation.INSTANCE.evaluate(...)':
final /*@NonNull*/ /*@Thrown*/ TupleValue symbol_0 = ValueUtil.createTupleOfEach(TutorialTables.TUPLid_, sum_4, le_0);
final /*@NonInvalid*/ boolean status = (Boolean)symbol_0.getValue(1/*status*/);
final /*@NonInvalid*/ boolean logDiagnostic = ClassUtil.nonNullState(CGStringLogDiagnosticOperation.INSTANCE.evaluate(evaluator, TypeId.BOOLEAN, TutorialTables.STR_Book_c_c_SufficientCopies, this, diagnostics, context, severity_0, status, TutorialTables.INT_0).booleanValue());
Thanks in advance for any help!
Kind regards
Matthias
Re: OCLinEcore: Custom validation messages not working [message #1700730 is a reply to message #1700726] Mon, 06 July 2015 13:06 Go to previous messageGo to next message
HI
Oops.
CGStringLogDiagnosticOperation was a late addition to support
configurable severities for safe navigation. I can easily understand how
it breaks the code as you have described. However I'm surprised that no
JUnit test detected the breakage. I'm also puzzled that I missed the
regression while reviewing all the tutorials for Mars.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=471948 raised.
Ed Willink
On 06/07/2015 17:48, Matthias Freund wrote:
> Hi all,
> in *Impl classes" Create the OCLinEcoreTutorial example
> described
> http://help.eclipse.org/mars/index.jsp?topic=%2Forg.eclipse.ocl.doc%2Fhelp%2FIntegration.html
> Model Editor')
> error message.
> Kind regards
> Matthias
Re: OCLinEcore: Custom validation messages not working [message #1700750 is a reply to message #1700730] Mon, 06 July 2015 15:10 Go to previous messageGo to next message
thanks for the quick response!
Kind regards
Matthias
Re: OCLinEcore: Custom validation messages not working [message #1700869 is a reply to message #1700750] Tue, 07 July 2015 14:21 Go to previous messageGo to next message
I hope that you find
http://www.eclipse.org/modeling/download.php?file=/modeling/mdt/ocl/downloads/drops/6.0.1/N201507071256/mdt-ocl-Update-N201507071256.zip
fixes the problem.
Ed Willink
On 06/07/2015 20:10, Matthias Freund wrote:
> Kind regards
> Matthias
Re: OCLinEcore: Custom validation messages not working [message #1700930 is a reply to message #1700869] Wed, 08 July 2015 05:16 Go to previous messageGo to next message
thanks! Now it works... Smile
Kind regards
Matthias
Re: OCLinEcore: Custom validation messages not working [message #1817977 is a reply to message #1700726] Tue, 03 December 2019 14:15 Go to previous messageGo to next message
I also try to generate custom messages but fail, started with the example from the library tutorial:
invariant SufficientCopies('There are '
+ library.loans->select((book = self))->size().toString()
+ ' loans for the ' + copies.toString() + ' copies of \'' + name + '\''):
library.loans->select((book = self))->size() <= copies;
Generated the code for the library tutorial and did a test run resulting in the built in report.
The documentation says the generated validator class must extend OCLinEcoreEObjectValidator instead of EObjectValidator so I changed that and added
"import org.eclipse.ocl.xtext.oclinecore.validation.OCLinEcoreEObjectValidator;"
and got the error
"The import org.eclipse.ocl.xtext cannot be resolved"
OCLinEcoreEObjectValidator documentation has a warning "This class may go obsolete once Bug 337792 resolved".
Another solved bugreport 471948 says a call to OCLinEcoreEObjectValidator is now working.
Then I debugged the existing code and found that the EObjectValidator validate method has an expression string with a "Tuple ..." containing the above message. But the message string is not transferred to the reportConstraintDelegateViolation method that generates the standard message.
Did I make a mistake somewhere or is the custom messaging not working?
I am using latest Eclipse (2019-09) and latest OCL downloads.
First I put this message in the bugreport337792, a mistake sorry about that.
Would much appreciate help on this.
Lars-Ola Österlund
Re: OCLinEcore: Custom validation messages not working [message #1818001 is a reply to message #1817977] Wed, 04 December 2019 01:28 Go to previous message
See the answer to the duplicate 'posting' to https://bugs.eclipse.org/bugs/show_bug.cgi?id=337792
Ed Willink
Previous Topic:Problems with a loop
Next Topic:Parsing constraints having elements from differents packages
Current Time: Sat Jul 26 21:05:58 EDT 2025
Powered by FUDForum. Page generated in 0.29952 seconds
