Home » Eclipse Projects » Oomph » Skipping Oomph setup
Skipping Oomph setup [message #1612863] Thu, 12 February 2015 03:54 Go to next message
We have some automated test that unzip some IDE package in a new directory and that perform some installation steps on top of it. Those use SWTBot to mimic installation scenario as we expect users to perform it.
The Oomph setup dialog pops-up early and messes up our SWTBot tests. Is there a way to skip this setup page?
Re: Skipping Oomph setup [message #1613775 is a reply to message #1612863] Thu, 12 February 2015 17:15 Go to previous messageGo to next message
Mickael,
These options give you control:
public static final String PROP_SETUP_SKIP = "oomph.setup.skip";
public static final String PROP_SETUP_QUESTIONNAIRE_SKIP =
"oomph.setup.questionnaire.skip";
On 12.02.2015 09:54, Mickael Istria wrote:
> Cheers,
Re: Skipping Oomph setup [message #1700449 is a reply to message #1613775] Thu, 02 July 2015 12:03 Go to previous messageGo to next message
Thansks Ed.
This has worked for some weeks, but with the latest Mars release, I now get an error in my automated tests: "java.lang.IllegalStateException: There is no eclipse.launcher property defined", which opens a pop-up and prevent my SWTBot tests to run. I tried to add a "-Dorg.eclipse.oomph.setup.skip=true" but that didn't work.
What would you advse to prevent this message from popping-up in automated tests?
Re: Skipping Oomph setup [message #1700459 is a reply to message #1700449] Thu, 02 July 2015 13:02 Go to previous messageGo to next message
Am 02.07.2015 um 18:03 schrieb Mickael Istria:
> Thansks Ed.
Please open a bugzilla and attach the complete stack trace so that we can see how you arrived at this point.
Cheers
/Eike
http://www.esc-net.de
Re: Skipping Oomph setup [message #1700460 is a reply to message #1700459] Thu, 02 July 2015 13:27 Go to previous messageGo to next message
Thanks, I opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=471731
Re: Skipping Oomph setup [message #1700462 is a reply to message #1700460] Thu, 02 July 2015 13:37 Go to previous messageGo to next message
Am 02.07.2015 um 19:27 schrieb Mickael Istria:
Sorry, I didn't see that earlier because you didn't show a stack trace here. The system property is just
-Doomph.setup.skip=true (not prefixed with "org.eclipse"). With that it should work.
Cheers
/Eike
Re: Skipping Oomph setup [message #1700465 is a reply to message #1700462] Thu, 02 July 2015 13:55 Go to previous messageGo to next message
BTW., most of our system properties start with "oomph...":
public interface SetupProperties
public static final String PROP_SETUP_QUESTIONNAIRE_SKIP = "oomph.setup.questionnaire.skip";
public static final String PROP_SETUP_OFFLINE_STARTUP = "oomph.setup.offline.startup";
public static final String PROP_SETUP_MIRRORS_STARTUP = "oomph.setup.mirrors.startup";
public static final String PROP_SETUP_OFFLINE = "oomph.setup.offline";
public static final String PROP_SETUP_MIRRORS = "eclipse.p2.mirrors";
public static final String PROP_SETUP_UNSIGNED_POLICY = "eclipse.p2.unsignedPolicy";
public static final String PROP_SETUP_REMOTE_DEBUG = "oomph.setup.remote.debug";
public static final String PROP_REDIRECTION_BASE = "oomph.redirection.";
public static final String PROP_UPDATE_URL = "oomph.update.url";
public static final String PROP_SETUP_PRODUCT_CATALOG_FILTER = "oomph.setup.product.catalog.filter";
public static final String PROP_SETUP_PRODUCT_FILTER = "oomph.setup.product.filter";
public static final String PROP_SETUP_PRODUCT_VERSION_FILTER = "oomph.setup.product.version.filter";
public static final String PROP_SETUP_JRE_CHOICE = "oomph.setup.jre.choice";
Cheers
/Eike
Re: Skipping Oomph setup [message #1700473 is a reply to message #1700465] Thu, 02 July 2015 14:41 Go to previous messageGo to next message
Ok, I looked at the wrong class apparently http://git.eclipse.org/c/cdo/org.eclipse.oomph.git/tree/plugins/org.eclipse.oomph.setup/src/org/eclipse/oomph/internal/setup/SetupProperties.java
Re: Skipping Oomph setup [message #1700476 is a reply to message #1700473] Thu, 02 July 2015 14:48 Go to previous message
Am 02.07.2015 um 20:41 schrieb Mickael Istria:
Yep, that whole repo is stone age :P
I guess I should remove it soon...
Cheers
/Eike
Previous Topic:component.def dependencies cached?
Next Topic:Targlet cannot be resolved
Current Time: Sun Nov 02 21:53:36 EST 2025
Powered by FUDForum. Page generated in 0.04989 seconds
