Home » Modeling » Papyrus » CSS Canonical does not work in SysML
CSS Canonical does not work in SysML [message #1700354] Thu, 02 July 2015 03:05 Go to next message
Hi, I've tested the canonical function of CSS with UML and SysML.
Here are my observations:
- UML :
+ canonical = true => all ports (of a certain part in a composite diagram) appears
+ however, right then, I modify canonical = false => the ports will not disappears. That means, once the properties are showed, they can not be unshowed by setting canonica = false
- SysML : canonical does not function in IBD
Could anyone show me how to get this done in SysML?
Thanks for your help.
Thanh Liem.
Re: CSS Canonical does not work in SysML [message #1700356 is a reply to message #1700354] Thu, 02 July 2015 03:09 Go to previous messageGo to next message
I've also noticed that, if I register a new DropEditPolicyProvider (with a new DropEditPolicy) via extension org.eclipse.gmf.runtime.diagram.ui.editPolicyProvides in Papyrus, the canonical function with not run even with UML diagrams.
Re: CSS Canonical does not work in SysML [message #1700364 is a reply to message #1700356] Thu, 02 July 2015 03:45 Go to previous messageGo to next message
Hi Liem,
That's intentional: the synchronization mechanism automatically displays everything (Populates the diagram), but it doesn't need to be active at all time. If the elements are not synchronized, then the mechanism simply does nothing. It doesn't keep track of elements that have been automatically synchronized, vs the ones that have been manually displayed.
Undoing canonical = true works, however.
Camille
Re: CSS Canonical does not work in SysML [message #1700414 is a reply to message #1700354] Thu, 02 July 2015 09:02 Go to previous messageGo to next message
Hi, Thanh Liem,
The canonical edit policy does not purport to remove views when it is
disabled. It only removes views for elements that should no longer be
shown as child nodes or connected edges because the structure of the
model has changed.
If the SysML IBD has some missing canonical behaviour, then perhaps it
needs to register some canonical strategies to make that work. Please
raise a bug on the SysML component.
Christian
On 2015-07-02 07:05:21 +0000, Thanh Liem Phan said:
> Hi, I've tested the canonical function of CSS with UML and SysML. Here
> - UML : + canonical = true => all ports (of a certain part in a
> Thanh Liem.
Re: CSS Canonical does not work in SysML [message #1700416 is a reply to message #1700356] Thu, 02 July 2015 09:06 Go to previous messageGo to next message
The Papyrus mechanism for customization of drag-and-drop on the
diagrams is the "drop strategies" extension point:
org.eclipse.papyrus.infra.gmfdiag.dnd.dropStrategy. By replacing the
Papyrus drop edit policy via the GMF extension point, you have removed
the mechanism that the canonical edit-policy relies on for creation of
new diagram views.
So, try implementing your custom drop behaviour using a drop strategy
instead and see whether that restores the canonical presentation.
HTH,
Christian
Re: CSS Canonical does not work in SysML [message #1700833 is a reply to message #1700416] Tue, 07 July 2015 09:36 Go to previous messageGo to next message
Thanks Christian,
The fact that I need to set myDragDropStrategy as a drag&drop default strategy also. So if I don't replace the default DropEditPolicyProvider by a new one, I couldn't achieve this requirement, and each time user drag&drop a component from the lib, Papyrus will display a list of strategy to choose.
And it's redundant action for the end user.
Do you have any idea?
[Updated on: Tue, 07 July 2015 09:40] by Moderator
Re: CSS Canonical does not work in SysML [message #1700837 is a reply to message #1700833] Tue, 07 July 2015 09:50 Go to previous messageGo to next message
Right, probably best to set your drop strategy as a default to
encourage consistent behaviour for your users.
I know of no definitive means by which you can avoid the drop
strategies contributed by plug-ins. There may be a Preference Page in
which you can selectively disable drop strategies. If there isn't,
there should be one (please raise a bugzilla in this case).
Christian
Re: CSS Canonical does not work in SysML [message #1700906 is a reply to message #1700837] Wed, 08 July 2015 02:50 Go to previous messageGo to next message
Thanks Christian, I will try with the Preference Page solution in order to set the default drag&drop strategie.
By the way, if it's not so complicated, could you show me how to set the canonical strategies for SysML?
Thanks and best regards.
Thanh Liem.
Re: CSS Canonical does not work in SysML [message #1700999 is a reply to message #1700906] Wed, 08 July 2015 10:47 Go to previous messageGo to next message
Hi, Thanh Liem,
What do you mean by "set the canonical strategies for SysML"? It's up
to the SysML diagrams to define strategies (if required) for canonical
synchronization. This isn't intended for user extensibility.
Christian
> Thanh Liem.
Re: CSS Canonical does not work in SysML [message #1701045 is a reply to message #1700999] Wed, 08 July 2015 17:18 Go to previous messageGo to next message
Hi Christian,
I just reuse your phrase in the previous reply.
But, may be i misunderstood.
Thanks.
Thanh Liem.
Re: CSS Canonical does not work in SysML [message #1701068 is a reply to message #1700354] Thu, 09 July 2015 03:46 Go to previous messageGo to next message
Hi Christian,
When I register a new D&D strategy (disable the registration of the new EditPolicyProviders), the popup menu is like the following :
index.php/fa/22448/0/
There are two dnd strategies in this case:
- the new one I've just created "Drop the component from the Spider Library"
- and "Selection drop action for"
But in fact, "Selection drop action for" is not listed in the Preferences\Papyrus\Drag&Drop. This is a default DnD strategy, which is created "on the fly" in the class DropEditPolicy, which is then instantiated by DropEditPolicyProvider.
That means, evens I deselect all d&d strategies but my own one (cf the figure below), the popup menu is always displayed when user drag&drop a component from model lib.
index.php/fa/22449/0/
Thanks and have a nice day.
PTL.
Re: CSS Canonical does not work in SysML [message #1701118 is a reply to message #1701068] Thu, 09 July 2015 09:01 Go to previous message
Hi, PTL,
That is a bug. Would you mind raising it in bugzilla?
https://bugs.eclipse.org/bugs/enter_bug.cgi?form_name=enter_bug&product=Papyrus&version=1.1.0
Thanks!
Christian
On 2015-07-09 07:46:37 +0000, Thanh Liem Phan said:
> Hi Christian,
> PTL.
> <image>
> <image>
Previous Topic:Export Product problem
Next Topic:Papyrus Video Tutorials for Beginners
Current Time: Sat Jul 26 21:21:49 EDT 2025
Powered by FUDForum. Page generated in 0.09215 seconds
