Home » Archived » Jubula » how to pass test or stored variables to an external script in Jubula
how to pass test or stored variables to an external script in Jubula [message #1700288] Wed, 01 July 2015 09:30 Go to next message
Hello Everyone,
Please how can i pass stored stored variable to an external command in Jubula
I have a batch script
@echo off
REM Verify Content from Database
REM Jubula
setlocal
echo connect xxxx/xxxx@1.2.3.4:1224/XXXXX.HAHAHA.WEST
echo set head off
echo set echo off
echo whenever sqlerror exit 2;
echo select XXXX from CUST where XXXX = '%XXXX%';
 echo exit^;
) > verifycustomercreation.sql
:verify_sql_script
sqlplus -s /nolog @verifycustomercreation.sql > result
IF errorlevel 0 goto return_OK
IF errorlevel 2 goto return_NOK
:return_OK
echo %errorlevel%
goto end
:return_NOK
echo %errorlevel%
goto end
:end
exit /b %errorlevel%
I would like to know how i can pass the value stored in Jubula to %XXXX% on the script. I noticed that by default it's not working. even though i have setlocal at the beginning of my script.
index.php/fa/22366/0/
index.php/fa/22367/0/
Thank you in advance for your response.
Kind regards,
Dave
[Updated on: Wed, 01 July 2015 09:32] by Moderator
Re: how to pass test or stored variables to an external script in Jubula [message #1700464 is a reply to message #1700288] Thu, 02 July 2015 13:59 Go to previous messageGo to next message
Can't you just append a space followed by "$CUST_NAME" (without quotes) to the end of the COMMAND parameter?
[Updated on: Thu, 02 July 2015 14:00] by Moderator
Re: how to pass test or stored variables to an external script in Jubula [message #1700486 is a reply to message #1700464] Thu, 02 July 2015 17:37 Go to previous messageGo to next message
Thank you
Re: how to pass test or stored variables to an external script in Jubula [message #1700522 is a reply to message #1700486] Fri, 03 July 2015 04:39 Go to previous message
please Keep [1] and [2] in mind.
Oliver
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=470982
[2] https://bugs.eclipse.org/bugs/show_bug.cgi?id=470983
Previous Topic:Check for difference between two values
Next Topic:Entering a component name in column New Name causes ecxeption
Current Time: Mon Nov 03 04:39:25 EST 2025
Powered by FUDForum. Page generated in 0.04348 seconds
