Home » Modeling » Compare » Problems with the Diff-Feature
Problems with the Diff-Feature [message #1689364] Mon, 23 March 2015 08:01 Go to next message
Hello there,
i am new to EMF-Compare and i use it to compare parts of my models. I have enountered a problem with the comparison where there are differences but the compare algorithm cant find them.
here are my two models
index.php/fa/21275/0/
index.php/fa/21276/0/
Here is the code i use:
IComparisonScope scope = new DefaultComparisonScope(sourceEPackage,
				deletedModelEPackage, null);
Comparison comparison = EMFCompare.builder().build().compare(scope);
List<Diff> differences = comparison.getDifferences();
After i have run the code the list is empty.
Any other changes are found and properly shown.
The model on picture 2 is contained in another element not shown in the screenshot. Is it possible that this causes the error?
I am using org.eclipse.emf.compare with version 3.0.2.201501201328
I would appreciate any help. Thank you.
Re: Problems with the Diff-Feature [message #1689468 is a reply to message #1689364] Mon, 23 March 2015 12:36 Go to previous messageGo to next message
Hi Simon,
Unfortunately, EMF Compare doesn't support the comparison of EGenerics inside EType Parameters yet. So it is normal that you see no differences in your case.
You can raise an enhancement bug to describe what you need: https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EMFCompare
If you're interested to contribute to EMF Compare and manage this case, you can follow the contributor guide: https://wiki.eclipse.org/EMF_Compare/Contributor_Guide
Re: Problems with the Diff-Feature [message #1700260 is a reply to message #1689468] Wed, 01 July 2015 05:52 Go to previous messageGo to next message
i made an enchancement request but unortunatly no one responds. is there something wrong with it? https://bugs.eclipse.org/bugs/show_bug.cgi?id=467816
Re: Problems with the Diff-Feature [message #1700510 is a reply to message #1700260] Fri, 03 July 2015 03:20 Go to previous messageGo to next message
Simon,
There is nothing wrong with your enhancement request, just that we missed it among the rest of the active bugzilla entries. Then again, this particular issue is not a priority for the EMF Compare team as there are more pressing bugs to handle.
We are open to contributions though, and we look at contributed patches asap. So if this issue is important for you and you want to try and tackle it yourself, please do. You'll probably have to look in the direction of our org.eclipse.emf.compare.diff.FeatureFilter , since we probably filter out the differences on EGenericTypes.
Laurent Goubet
Obeo
Re: Problems with the Diff-Feature [message #1700784 is a reply to message #1700510] Tue, 07 July 2015 03:46 Go to previous message
Hello Laurent,
thank you for your reply. i will try to free up some time to look into the featurefilter.
Greetings
Previous Topic:Model Resolving step
Next Topic:Consider cross references for comparison
Current Time: Sat Jul 26 12:55:24 EDT 2025
Powered by FUDForum. Page generated in 0.04970 seconds
