Home » Archived » Sapphire » How to get the current caret position of a field
How to get the current caret position of a field [message #1699943] Mon, 29 June 2015 08:37 Go to next message
I would like to mimic a feature known from some UI parts in Eclipse (especially launch configurations) - inserting a predefined variable. It allows to modify the value of a text field by inserting a special value to the position of the caret.
I'm struggling with how to get the caret position in Sapphire since the model does not propagate such UI-specific info. Is there a way how to implement this which does not involve creating a special field implementation?
Thanks in advance.
[Updated on: Mon, 29 June 2015 08:38] by Moderator
Re: How to get the current caret position of a field [message #1701511 is a reply to message #1699943] Mon, 13 July 2015 14:50 Go to previous messageGo to next message
Sorry for the delay in responding. Currently, there is no API available to implement what you are describing. We should add a TextSelectionService similar to the existing ListSelectionService.
Re: How to get the current caret position of a field [message #1706690 is a reply to message #1701511] Fri, 28 August 2015 13:51 Go to previous message
I had a bit of time recently to implement a ListSelectionService. Take a look and let us know how it worked for your usecase. There is a sample that shows you how to manipulate selection/caret and how to insert at current selection/caret.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=474735
Previous Topic:Drag and Drop support for a list of string items
Next Topic:Default values behavior in property editor.
Current Time: Tue Oct 28 17:25:25 EDT 2025
Powered by FUDForum. Page generated in 0.05986 seconds
