Home » Newcomers » Newcomers » Maven integration for Eclipse Ganymede 3.4.2
Maven integration for Eclipse Ganymede 3.4.2 [message #1699897] Mon, 29 June 2015 01:28 Go to next message
I have been using all the versions of Eclipse, but recently tried installing Maven for Eclipse Ganymede 3.4.2. It throws an error " No Repository found at http //download.eclipse.org/technology/m2e/releases".
can anybody help me out why for this version of Eclipse it is throwing this error.
Re: Maven integration for Eclipse Ganymede 3.4.2 [message #1700068 is a reply to message #1699897] Mon, 29 June 2015 19:21 Go to previous messageGo to next message
> this error.
> Thanks
You're joking, right? Ganymede is something like 8 years old now, no?
Re: Maven integration for Eclipse Ganymede 3.4.2 [message #1700395 is a reply to message #1700068] Thu, 02 July 2015 07:31 Go to previous messageGo to next message
ya probably, but that's how the application needs.
Can we integrate or add a plugin for maven to the said ganymede 3.4 or a higher version of eclipse is compulsory??
Re: Maven integration for Eclipse Ganymede 3.4.2 [message #1700408 is a reply to message #1700395] Thu, 02 July 2015 08:37 Go to previous message
First, a "higher version" of Eclipse is not mandatory. Selecting an
ancient version like Ganymede only means that for support you rely upon
dim and, frankly, unwilling memories.
Second, it's very hard to imagine that Ganymede is "how the application
needs." Eclipse is a general purpose IDE. There are technologies that
fade into nothing, cvs and svn come to mind; there are other projects
supported by Eclipse in the past that have come to an end, but
end-of-life technologies should end for the most part. This is a sign
that if the application is that important to resurrect, it's probably
also worthy of being fixed to abandon the old.
Hope this helps.
Why not discuss exactly why you need Ganymede and we'll help you over
that need? I've used Eclipse since Europa and, of all the versions I
used, that one was my least favorite in terms of reliability.
Previous Topic:"gcc" program could not be found
Next Topic:Finding a class in the ...\plugins directory
Current Time: Sun Jun 01 11:15:49 EDT 2025
Powered by FUDForum. Page generated in 0.07626 seconds
