Home » Newcomers » Newcomers » Finding a class in the ...\plugins directory(What is the current best practice for finding a class in the ...\plugins directory)
Finding a class in the ...\plugins directory [message #1699829] Fri, 26 June 2015 18:56 Go to next message
Way back I found a plug-in from IBM Alpha works called "jarclassfinder" that allow me to search all .jar files in a directory for .jar that had the requested class name. The "jarclassfinder" is not on Alphaworks anymore. I am now back doing some eclipse work and and trying to find the equivalent functionality. Then I did a google search and found "classLocator" on sourceforge. Tried that by dropping the "classlocator.jar" file in the plugins directory and the dropins directories and did not show up either way.
My question is this....
What is the current best practice (tool) for finding a class in the ...\plugins directory. I saw no such feature (tab) in the "search -> search" panel.
Re: Finding a class in the ...\plugins directory [message #1700033 is a reply to message #1699829] Mon, 29 June 2015 14:38 Go to previous messageGo to next message
From the main Plug-in Development preference page, make sure the checkbox for "Include all plug-ins from target in Java Search" is on. Then you'll be able to use the Open Type command on their types. You might have to disable the Package/Project Explorer's "External Plug-in Libraries" Filter to see the actual jar file.
[Updated on: Mon, 29 June 2015 14:39] by Moderator
Re: Finding a class in the ...\plugins directory [message #1700333 is a reply to message #1700033] Wed, 01 July 2015 19:39 Go to previous messageGo to next message
Apparently I was not very clear. I need to search a directory full of *.jar files, which is NOT already configured as a library in a Eclipse Plug-in Project for a Java Class.
Re: Finding a class in the ...\plugins directory [message #1700448 is a reply to message #1700333] Thu, 02 July 2015 11:46 Go to previous messageGo to next message
Do you need to do this from an external command line, or somehow integrated into Eclipse? If the former, and you're running in an environment where you can run Perl scripts from your command line (Unix, Linux, Cygwin, or perhaps ActiveState Perl), I wrote a small suite of Perl scripts for searching for files in zip archives.
Re: Finding a class in the ...\plugins directory [message #1700454 is a reply to message #1700448] Thu, 02 July 2015 12:32 Go to previous message
I have uploaded and attached the plug-in zip file that worked in Eclipse 3.0. I tried getting it to work in Eclipse 4.4.2 but it does not show up on the menu and I see no errors. Is it possible someone with deeper Eclipse skills can see what is going on?
Previous Topic:Maven integration for Eclipse Ganymede 3.4.2
Next Topic:Eclipse certification??
Current Time: Sat Jul 26 10:58:06 EDT 2025
Powered by FUDForum. Page generated in 0.12524 seconds
