Home » Modeling » TMF (Xtext) » Strange trace files after code generation! Are they generated by XText?(We are getting many trace files after generating code from our DSL.)
Strange trace files after code generation! Are they generated by XText? [message #1699720] Fri, 26 June 2015 03:39 Go to next message
We have a DSL from which we generate C-Code (.c and .h files). The project build (especially on Windows platform) is very slow mainly due to refreshing and indexing (by Eclipse CDT) mysterious trace files.
Currently we don't know which part of the framework is responsible for generating these trace files (CDT, XText, Eclipse, whatever ...).
We were not able to analyse the content of the trace file, since none of the files appear at the file system.
The filename syntax is as follows:
For a C source code file "/project/src-gen/my_c_function.c" the following trace file gets generated: "/project/src-gen/.my_c_function.c._trace"
Does anybody know if XText is responsible for this ?
  • Attachment: traces.png
    (Size: 31.81KB, Downloaded 294 times)
Re: Strange trace files after code generation! Are they generated by XText? [message #1699732 is a reply to message #1699720] Fri, 26 June 2015 04:44 Go to previous messageGo to next message
Xtext produces such trace files if you have a generator that does so
explicitly. There is no code in Xtext that indexes these files somehow
during a build.
Best,
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Find help at http://xtext.itemis.com or xtext(@)itemis.com
Blog: zarnekow.blogspot.com
Twitter: @szarnekow
Google+: https://www.google.com/+SebastianZarnekow
Re: Strange trace files after code generation! Are they generated by XText? [message #1699751 is a reply to message #1699732] Fri, 26 June 2015 06:58 Go to previous messageGo to next message
Thats good news.
Indexing is done by the CDT (as I mentioned in my original post) and this takes additional time.
I'm very curious on what's the purpose or content of these files and how to turn generation of trace files off.
Re: Strange trace files after code generation! Are they generated by XText? [message #1699847 is a reply to message #1699720] Sat, 27 June 2015 02:26 Go to previous messageGo to next message
You may be interested in https://bugs.eclipse.org/bugs/show_bug.cgi?id=471103
I created a patch for CDT 8.6 (Luna version) that boosts the indexing speed significantly. The sources are available at https://github.com/kthoms/cdt/tree/cdt86_perf_index.
Re: Strange trace files after code generation! Are they generated by XText? [message #1699863 is a reply to message #1699751] Sat, 27 June 2015 14:09 Go to previous messageGo to next message
On 26.06.15 12:58, Wolfgang Zeller wrote:
> Thats good news.
Hi Wolfgang,
the trace files contain the mapping from DSL files to generated code.
This is used for the navigation. I wonder why CDT tries to index _trace
files. Is this a known file extension in your environment?
Best,
Sebastian
Twitter: @szarnekow
Re: Strange trace files after code generation! Are they generated by XText? [message #1700135 is a reply to message #1699863] Tue, 30 June 2015 07:17 Go to previous messageGo to next message
*._trace Files were associated with a "Trace File Viewer". We have no clue what this is or where it comes from. I have removed this file association, but this didn't help (see screenshot).
Another very strange thing is that the trace files (like the one shown in the screenshot) do not exist in the file system.
Is there a way to deactivate this trace file handling in the XText generator framework?
Re: Strange trace files after code generation! Are they generated by XText? [message #1700215 is a reply to message #1700135] Tue, 30 June 2015 16:30 Go to previous messageGo to next message
Usually the files exist in the FS but are hidden by the project explorer
by default since their name starts with a '.'.
Also generating trace files needs to be enabled explicitly so I assume
your language impl does that on purpose. Make sure that your code
generator passes an instance of java.lang.String to the file system
access to suppress trace files.
Best,
Sebastian
Twitter: @szarnekow
Re: Strange trace files after code generation! Are they generated by XText? [message #1700238 is a reply to message #1700215] Wed, 01 July 2015 02:45 Go to previous messageGo to next message
Windows explorer definitely shows hidden files on my computer. I've checked this by manually creating a file with the same file name pattern as the XText trace files. I've checked this many times now and never saw a trace file generated by XText in the file system.
The next annoying thing is that none of our developers have a knowledge about the trace files in general, nor do they know how to switch trace file generation on or off.
We studied our workflow file and didn't find anything suspicious. Can I find further information regarding the trace files in the XText documentation?
Re: Strange trace files after code generation! Are they generated by XText? [message #1700241 is a reply to message #1700238] Wed, 01 July 2015 03:26 Go to previous messageGo to next message
Hi Wolfgang,
Xtext does not put tracefiles into some hidden channel on your
filesystem. They may stem from somewhere else than.
You're right, there is no official documentation on the trace files or
their format.
I'm not sure how to proceed from here to solve your issue. You could
either debug it yourself starting from TraceRegionSerializer or drop me
a mail if you need professional support to resolve the issue.
Best,
Sebastian
Twitter: @szarnekow
Re: Strange trace files after code generation! Are they generated by XText? [message #1700349 is a reply to message #1700241] Thu, 02 July 2015 01:58 Go to previous messageGo to next message
Many thanks for your support so far.
Debugging the code gave us some new information. Our generator does not create the trace files but the XText framework tries to access trace files for generated code during the build process. During this process, XText checks the existence of each trace file and if they do not exist, it simply continues.
The problem is that we are using Git (EGit) for our projects. For any reason, EGit wants to refresh the Git status of the trace files and produces nice "hangs" (sometimes minutes for a single "non-existing" trace file).
We have tried several patterns for the trace files in our .gitignore file with no positive effect.
Is there anybody outside who can help us to make at least a small step forward?
Re: Strange trace files after code generation! Are they generated by XText? [message #1700376 is a reply to message #1700349] Thu, 02 July 2015 04:53 Go to previous messageGo to next message
Sounds like a bad bug. I would progress in two ways.
Load EGIT as source and profile to see where the time goes.
Use Wireshark to see if unexpected Internet traffic is occurring quite
possibly with long timeouts.
Ed Willink
> trace file).
> forward?
Re: Strange trace files after code generation! Are they generated by XText? [message #1700431 is a reply to message #1700376] Thu, 02 July 2015 10:32 Go to previous messageGo to next message
Flight Recorder told us that most of the time is spent in
org.eclipse.jgit.fnmatch.FileNameMatcher.extendStringToMatchByOneCharacter(char)
[Updated on: Mon, 13 July 2015 06:43] by Moderator
Re: Strange trace files after code generation! Are they generated by XText? [message #1720974 is a reply to message #1700431] Fri, 22 January 2016 04:30 Go to previous messageGo to next message
Hi ,
I am unable to ignore these trace file from my git . I see these getting generated .
I used *.java._trace in gitignore. Any suggestion would be much appreciated.
Re: Strange trace files after code generation! Are they generated by XText? [message #1720978 is a reply to message #1720974] Fri, 22 January 2016 04:35 Go to previous messageGo to next message
https://github.com/eclipse/xtext/blob/master/.gitignore
Re: Strange trace files after code generation! Are they generated by XText? [message #1797977 is a reply to message #1720978] Fri, 09 November 2018 07:43 Go to previous message
try
**/*.java._trace
Previous Topic:Testing Xtext Language Server for generic IDE
Next Topic:[Xbase] Problems with types and scoping in Xbase-based DSL
Current Time: Sat Jul 19 02:03:44 EDT 2025
Powered by FUDForum. Page generated in 0.06915 seconds
