Home » Modeling » Papyrus » Sequence to communication diagram convertion(Sequence to communication diagram convertion)
Sequence to communication diagram convertion [message #1699511] Wed, 24 June 2015 12:43 Go to next message
is it possible to convert a Sequence diagram to a communication one with papyrus ?
If yes, how ?
Thanks.
Re: Sequence to communication diagram convertion [message #1699635 is a reply to message #1699511] Thu, 25 June 2015 08:28 Go to previous message
With the new support for canonical diagram views in Papyrus 1.1 (Mars
release), you should be able to populate a communication diagram easily
from an existing Interaction.
Create a new communication diagram in the interaction, then attach a
CSS stylesheet to it that has a rule like this:
* { canonical: true; }
All of your lifelines and messages should now appear. You can remove
the stylesheet at this point if you like, or leave it to let the
diagram continue to pick up new content from the interaction.
Refer to these videos for more details:
https://youtu.be/NhdDWIlpXao -- initial canonical views implementation
https://youtu.be/aOcCthCuDBI -- properties controlling canonical views
https://youtu.be/cfoQQKPlsxw -- CSS support for canonical views
https://youtu.be/EyfP9HicfDI -- short overview (less than 2 minutes)
HTH,
Christian
On 2015-06-24 16:43:03 +0000, Herve Rogues said:
> Hello,
> with papyrus ?
> If yes, how ?
> Thanks.
Previous Topic:uml profile and State machines
Next Topic:In braces view on packages, not shown 'inside' tab
Current Time: Mon Jul 28 03:34:15 EDT 2025
Powered by FUDForum. Page generated in 0.27676 seconds
