Home » Language IDEs » ServerTools (WTP) » WSDL Editor question
WSDL Editor question [message #169928] Tue, 23 May 2006 15:32 Go to next message
Just a quick q (I am new to WSDL). When I create a new WSDL doc, why are
all elements within the WSDL prefixed with wsdl: ?
I am reading some docs on WSDL 2.0, and they state that if there is a
desecription element defined with the wsdl 2.0 namespace defined, there is
no need to prefix all the elements.
Thanx for the clarification ahead of time.
Re: WSDL Editor question [message #170230 is a reply to message #169928] Fri, 26 May 2006 12:59 Go to previous message
is
The prefix is there because WSDL is an XML language that uses namespaces.
You're correct that the elements do not have to be prefixed. If the WSDL
namespace is specified as the default using xmlns="" all non-prefixed
elements will be in the WSDL namespace. In this case your definitions
element will look something like
<definitions name="Echo"
targetNamespace="http://www.example.org/Echo/"
xmlns:tns="http://www.example.org/Echo/"
xmlns="http://schemas.xmlsoap.org/wsdl/"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/">
</definitions>
as opposed to the following editor default
<wsdl:definitions name="Echo"
xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/"
</wsdl:definitions>
Lawrence
Previous Topic:location of tomcat configuration
Next Topic:NoClassDefFoundError: org/eclipse/wst/common/componentcore/GlobalComponentChangeListener
Current Time: Fri Jul 25 21:34:16 EDT 2025
Powered by FUDForum. Page generated in 0.03101 seconds
