Home » Modeling » OCL » How to create an invariant for an UML class in OCL 6.0?
How to create an invariant for an UML class in OCL 6.0? [message #1699203] Mon, 22 June 2015 10:26 Go to next message
There is a very simple program which defines the OCL constraint for the Person UML class:
https://github.com/AresEkb/ocl6_test
package ocl6_test;
import java.io.File;
import java.util.Iterator;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.ocl.pivot.Element;
import org.eclipse.ocl.pivot.ExpressionInOCL;
import org.eclipse.ocl.pivot.resource.ASResource;
import org.eclipse.ocl.pivot.utilities.OCL;
import org.eclipse.ocl.pivot.utilities.OCLHelper;
import org.eclipse.ocl.pivot.utilities.ParserException;
import org.eclipse.uml2.uml.Model;
import org.eclipse.uml2.uml.Class;
import org.eclipse.uml2.uml.UMLPackage;
public class Main {
        final String input = "model/My.uml";
        System.out.println("Initialization");
        ResourceSet rs = new ResourceSetImpl();
        rs.setURIConverter(new CustomURIConverter());
        org.eclipse.ocl.pivot.model.OCLstdlib.install();
        org.eclipse.ocl.pivot.uml.UMLStandaloneSetup.init();
        OCL ocl = OCL.newInstance(rs);
        System.out.println("Loading UML model " + input);
        Resource resource = ocl.getResourceSet().getResource(createFileURI(input), true);
        Model uml = (Model)EcoreUtil.getObjectByType(resource.getContents(), UMLPackage.eINSTANCE.getModel());
        System.out.println("Root: " + uml);
        Class person = (Class)uml.getPackagedElement("Person");
        System.out.println("Class: " + person);
        try {
            OCLHelper helper = ocl.createOCLHelper(person);
            System.out.println("Helper: " + helper);
            System.out.println("Context: " + helper.getContextClass());
            ExpressionInOCL expr = ocl.createInvariant(person, "age2 > 0");
            System.out.println("Expression: " + expr);
        catch (ParserException e) {
            e.printStackTrace();
        ocl.dispose();
    private static URI createFileURI(String relativePath)
        return URI.createFileURI(new File(relativePath).getAbsolutePath());
The problem is that it throws the exception:
Exception in thread "main" java.lang.IllegalStateException: Undefined contextClass
	at org.eclipse.ocl.pivot.internal.helper.OCLHelperImpl.createInvariant(OCLHelperImpl.java:110)
	at org.eclipse.ocl.pivot.utilities.OCL.createInvariant(OCL.java:261)
	at ocl6_test.Main.main(Main.java:48)
As far I understand I shoud pass an org.eclipse.ocl.pivot.Class (instead of org.eclipse.uml2.uml.Class) into the ocl.createInvariant() method. Am I right? But how can I get a pivot Class for the UML Class?
Re: How to create an invariant for an UML class in OCL 6.0? [message #1699226 is a reply to message #1699203] Mon, 22 June 2015 13:49 Go to previous messageGo to next message
You just need.
org.eclipse.ocl.pivot.Class asPerson =
ocl.getMetamodelManager().getASOf(org.eclipse.ocl.pivot.Class.class,
person);
When you run you will get a nice error message telling you that you need
EssentialOCLStandaloneSetup.doSetup();
The following now happens pretty automatically (lazily)
getASOf is a new more flexible API than getASOfEcore (formerly
getPivotOfEcore). It supports any plugged-in External Syntax technology;
currently just Ecore and optionally UML2.
(org.eclipse.ocl.pivot.as_resource_factory extension point.)
Unfortunately getASOf is not used as widely as it could be. Bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=470738 raised. Once this
is fixed, your program would work as is, up until the error message
diagnosing the missing EssentialOCLStandaloneSetup.doSetup();
Ed Willink
On 22/06/2015 15:26, Denis Nikiforov wrote:
> Hi
> package ocl6_test;
> public class Main {
> public static void main(String[] args) {
> Resource resource =
> Model uml =
> try {
> 0");
> ocl.dispose();
> contextClass
> at
Re: How to create an invariant for an UML class in OCL 6.0? [message #1699254 is a reply to message #1699226] Tue, 23 June 2015 01:36 Go to previous messageGo to next message
Thanks a lot! It works!
It seems that the "Pivot Standalone Configuration" section in the documentation is a little bit outdated. The initialization is simpler now.
Re: How to create an invariant for an UML class in OCL 6.0? [message #1699256 is a reply to message #1699254] Tue, 23 June 2015 01:41 Go to previous messageGo to next message
Are you looking at the latest 6.0.0 documentation. I updated quite a lot
but time always runs out ...
Ed Willink
> now.
Re: How to create an invariant for an UML class in OCL 6.0? [message #1699259 is a reply to message #1699256] Tue, 23 June 2015 01:54 Go to previous message
I'm lookig at http://help.eclipse.org/mars/index.jsp?topic=%2Forg.eclipse.ocl.doc%2Fhelp%2FPivotStandalone.html&cp=49_6_2
Here is a list of possible initialization methods:
org.eclipse.ocl.pivot.OCL.initialize(resourceSet);
org.eclipse.ocl.pivot.uml.UML2AS.initialize(resourceSet);
org.eclipse.ocl.pivot.delegate.OCLDelegateDomain.initialize(resourceSet);
org.eclipse.ocl.xtext.completeocl.CompleteOCLStandaloneSetup.doSetup();
org.eclipse.ocl.xtext.oclinecore.OCLinEcoreStandaloneSetup.doSetup();
org.eclipse.ocl.xtext.oclstdlib.OCLstdlibStandaloneSetup.doSetup();
org.eclipse.ocl.domain.utilities.StandaloneProjectMap.getAdapter(resourceSet);
Previous Topic:How to import an UML element into a pivot model?
Next Topic:Announcing the Mars 6.0.0 Eclipse OCL release
Current Time: Thu Jul 17 23:23:59 EDT 2025
Powered by FUDForum. Page generated in 0.05482 seconds
