Problems with creating a Session [message #1699164] |
Mon, 22 June 2015 05:18  |
Hi all,
I have some serious problems with creating a Session when trying to integrate Sirius in a plugin into our RCP. I have read the documentation, but it seems to be outdated. The documentation refers to code that does not compile at the moment and I could really use some help.
The following snippet is from the docs:
URI sessionResourceURI = URI.createPlatformResourceURI("/Project/archi.aird", true);
Session createdSession = SessionManager.INSTANCE.getSession(sessionResourceURI);
createdSession.open();
However, the methods getSession(sessonResourceURI) and are modified in the current version and I can't get it to work. Does someone have an example when integrating sirius into a plugin for a RCP?
I could really use some help guys. Let me know if I need to clarify something.
Axel Niklasson
Re: Problems with creating a Session [message #1699415 is a reply to message #1699164] |
Wed, 24 June 2015 03:59   |
Le 23/06/2015 15:08, Axel Niklasson a écrit :
> Hi all,
> createdSession.open() are modified in the current version and I can't
To make that code compile just add new NullProgressMonitor(). (We will
update the doc).
SessionManager.INSTANCE.getSession(sessionResourceURI, new
NullProgressMonitor());
createdSession.open(new NullProgressMonitor());
> something.
Please, if not working, explain what you expect, what happen and
provides stack traces if need be.
> Regards,
> Axel Niklasson
Laurent
FUDForum. Page generated in 0.03484 seconds
