Home » Archived » BIRT » Chart Library for Standalone SWT Application?
Chart Library for Standalone SWT Application? [message #177845] Sat, 15 July 2006 06:11 Go to next message
I don't use BIRT, but I'm interested in the chart-library from BIRT (or
TPTP?). I develop an application with benchmark function and would display
the results as different graphical charts. I found the JFreeChart Library,
which is basically for Swing or AWT. But over the AWT_Frame and
SWT_Embedded it can be integrated in SWT Apps. But it is slow and now I
search for an other solution:
Is it possible to use the library in a standalone SWT App (no eclipse
plugin)? Are there any examples or code snippets? which libraries need I?
Thanks in advance!
Bye
Gerrit
Re: Chart Library for Standalone SWT Application? [message #177891 is a reply to message #177845] Mon, 17 July 2006 03:00 Go to previous messageGo to next message
Yes, you can use the BIRT charting library in a standalone SWT app. The
library is made of plugins, but can work outside eclipse. Please get the
chart engine download from the BIRT site and look at the examples plugin for
SWT examples.
David
"Gerrit Brehmer" <gbrehmer@yahoo.de> wrote in message
news:40b846ce5ac6fab80b60ccc8d2167848$1@www.eclipse.org...
> Thanks in advance!
> Bye
> Gerrit
Re: Chart Library for Standalone SWT Application? [message #179328 is a reply to message #177891] Fri, 21 July 2006 04:54 Go to previous messageGo to next message
Originally posted by: daniel.hassenpflug.hp.com
i've just tried out the examples. The SWT Applications start, but
everytime an exception like this occurs:
"21.07.2006 10:09:44 org.eclipse.birt.chart.util.PluginSettings instance
SCHWERWIEGEND: Exception
org.eclipse.birt.core.exception.BirtException: $NO-RB$ Can't startup the
OSGI framework
at org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:90)
at
org.eclipse.birt.chart.util.PluginSettings.instance(PluginSe ttings.java:241)
at
org.eclipse.birt.chart.util.PluginSettings.instance(PluginSe ttings.java:221)
at ChartViewerSWT.<init>(ChartViewerSWT.java:96)
at NewSWTApp.main(NewSWTApp.java:108)
Caused by: org.eclipse.birt.core.exception.BirtException: $NO-RB$ Could
not find the Framework - {0}
at
org.eclipse.birt.core.framework.osgi.OSGILauncher.startup(OS GILauncher.java:88)
at org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:78)
... 4 more
Changing the argument before running like -DSTANDALONE as well as
-DBIRT_HOME=D:\ReportEngine does not make any improvement. Does anybody
have an idea what to do?
Thanks for replies, Daniel
Re: Chart Library for Standalone SWT Application? [message #179393 is a reply to message #179328] Fri, 21 July 2006 07:40 Go to previous messageGo to next message
Problem is solved,
I've made a fault with the Standalone argument... -DSTANDALONE works fine,
Thanks, Daniel
Re: Chart Library for Standalone SWT Application? [message #179691 is a reply to message #179328] Mon, 24 July 2006 06:27 Go to previous messageGo to next message
This exception has no impact on the good execution of the code,
setting -DSTANDALONE should get rid of it in any case.
David
"Daniel" <daniel.hassenpflug@hp.com> wrote in message
news:0ca0e02157b6176f9cd213dac3cffa5a$1@www.eclipse.org...
> Hello,
> OSGI framework at
> at
> at
> at
> ... 4 more
> as -DBIRT_HOME=D:\ReportEngine does not make any improvement. Does anybody
Re: Chart Library for Standalone SWT Application? [message #1698995 is a reply to message #177845] Fri, 19 June 2015 07:31 Go to previous message
You can try charting library like koolchart, Highchart, Google free chart to create interactive charts.
[Updated on: Fri, 19 June 2015 16:15] by Moderator
Previous Topic:rounded corners on chart container
Next Topic:Column value missing in BIRT report for Cassandra data source
Current Time: Sat Jul 19 03:11:27 EDT 2025
Powered by FUDForum. Page generated in 0.51193 seconds
