Home » Newcomers » Newcomers » Eclipse Refuses to Run File(Eclipse newbie)
Eclipse Refuses to Run File [message #1698757] Wed, 17 June 2015 12:03 Go to next message
I have a file that is very clearly in my current workspace, in the src folder, and in the default packaege. Other Java files within this folder run just fine, but Eclipse will not give me an option to compile and run the EditerV2.java file (see screenshot attached) when I attempt to use the green play button.
  • Attachment: problem.png
    (Size: 83.79KB, Downloaded 120 times)
Re: Eclipse Refuses to Run File [message #1698771 is a reply to message #1698757] Wed, 17 June 2015 12:52 Go to previous message
You didn't show the entire file, but you're certain there is a proper main method?
Previous Topic:Eclipse Hangs
Next Topic:Help a newbie
Current Time: Fri Jun 06 14:34:46 EDT 2025
Powered by FUDForum. Page generated in 0.07129 seconds
