Home » Modeling » EMF » Drived attributes and custom bodies with EAttribute annotations with OCL
Drived attributes and custom bodies with EAttribute annotations with OCL [message #1698746] Wed, 17 June 2015 10:54 Go to next message
I am trying to customize the Java API generated from an example Ecore model by using EAnnotations with OCL, but have not managed to see any changes in the generated code.
My class includes a 'Name'-attribute and a 'DerivedName'-attribute with the following annotation:
<eAnnotations source="http://www.eclipse.org/2007/OCL">
<details key="derive" value="self.Name"/>
</eAnnotations>
I have updated the GenModel to use dynamic templates, added the plugin dependencies by adding OCL_ECORE=org.eclipse.ocl.ecore to the Model Plug-in Variables, and tried setting the transient and volatile attributes.
Any pointers to the below would be appreciated?
- documentation on the various eAnnotation-source accessible features and their constraints
- example projects where the EAnnotations are used to do derived attributes and customized bodies with OCL
Re: Drived attributes and custom bodies with EAttribute annotations with OCL [message #1698918 is a reply to message #1698746] Thu, 18 June 2015 15:08 Go to previous messageGo to next message
I've no idea where you got http://www.eclipse.org/2007/OCL. I'm guessing
that you're following some seriously vintage document.
Follow the OCLinEcore tutorial in the OCL documentation.
Ed Willink
> </eAnnotations>
> attributes.
Re: Drived attributes and custom bodies with EAttribute annotations with OCL [message #1698919 is a reply to message #1698918] Thu, 18 June 2015 15:13 Go to previous messageGo to next message
Looks like this:
https://www.eclipse.org/articles/article.php?file=Article-EMF-Codegen-with-OCL/index.html
Apparently, the entire Eclipse Corner article repository is deprecated.
Christian
On 2015-06-18 19:08:26 +0000, Ed Willink said:
> Hi
> guessing that you're following some seriously vintage document.
> Regards
> Ed Willink
>> </eAnnotations>
>> attributes.
Re: Drived attributes and custom bodies with EAttribute annotations with OCL [message #1699160 is a reply to message #1698919] Mon, 22 June 2015 04:44 Go to previous message
Yes. Seems like I took off from some legacy examples and then had an erroneous perception when initially looking into the OCL tutorial.
Managed to create examples and reverse engineer the proper details for driving my example of adding the annotations programmatically.
Thanks.
Previous Topic:Copy&paste / drag&drop into (different) FeatureMap attributes
Next Topic:[CDO] "Synchronizable repositories don't support dynamic addition of new packages"
Current Time: Wed Jul 23 13:24:59 EDT 2025
Powered by FUDForum. Page generated in 0.26437 seconds
