Home » Eclipse Projects » RCP Testing Tool » [SOLVED] Starting workbench failed(Starting workbench failed)
[SOLVED] Starting workbench failed [message #1698503] Tue, 16 June 2015 02:55 Go to next message
My AUT can't be started with the following error:
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2015-06-16 07:36:38.542
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!STACK 0
java.lang.NoClassDefFoundError: java/util/function/Function
	at com.cinnober.ttc.lme.util.MblDepthTabRenderer.getLabel(MblDepthTabRenderer.java:25)
	at com.cinnober.client.swt.util.CoreStackRenderer.updateBySecondaryId(CoreStackRenderer.java:75)
	at com.cinnober.client.swt.util.CoreStackRenderer.createTab(CoreStackRenderer.java:53)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.processContents(LazyStackRenderer.java:132)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:645)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:62)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:65)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
	at org.eclipse.swt.widgets.Display.syncExec_aroundBody12(Display.java:4688)
	at org.eclipse.swt.widgets.Display$AjcClosure13.run(Display.java:1)
	at org.eclipse.rcptt.tesla.swt.aspects.DisplayAspect.ajc$around$org_eclipse_rcptt_tesla_swt_aspects_DisplayAspect$9$400dfa49proceed(DisplayAspect.aj:1)
	at org.eclipse.rcptt.tesla.swt.aspects.DisplayAspect.ajc$around$org_eclipse_rcptt_tesla_swt_aspects_DisplayAspect$9$400dfa49(DisplayAspect.aj:329)
	at org.eclipse.swt.widgets.Display.syncExec_aroundBody14(Display.java:4684)
	at org.eclipse.swt.widgets.Display$AjcClosure15.run(Display.java:1)
	at org.eclipse.rcptt.sherlock.aspects.swt.DisplayAspect.ajc$around$org_eclipse_rcptt_sherlock_aspects_swt_DisplayAspect$1$400dfa49proceed(DisplayAspect.aj:1)
	at org.eclipse.rcptt.sherlock.aspects.swt.DisplayAspect.ajc$around$org_eclipse_rcptt_sherlock_aspects_swt_DisplayAspect$1$400dfa49(DisplayAspect.aj:28)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4684)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:205)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:135)
	at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:1)
	at org.eclipse.ui.internal.WorkbenchPage.setPerspective(WorkbenchPage.java:3933)
	at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:675)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:84)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:73)
	at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1400)
	at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1373)
	at org.eclipse.ui.internal.services.WorkbenchSourceProvider.updateActiveShell(WorkbenchSourceProvider.java:924)
	at org.eclipse.ui.internal.services.WorkbenchSourceProvider.getCurrentState(WorkbenchSourceProvider.java:133)
	at org.eclipse.ui.internal.services.WorkbenchSourceProvider$6.handleEvent(WorkbenchSourceProvider.java:684)
	at org.eclipse.swt.widgets.Display.filterEvent_aroundBody2(Display.java:1262)
	at org.eclipse.swt.widgets.Display$AjcClosure3.run(Display.java:1)
	at org.eclipse.rcptt.tesla.recording.aspects.RecordingAspect.ajc$around$org_eclipse_rcptt_tesla_recording_aspects_RecordingAspect$5$a74609acproceed(RecordingAspect.aj:1)
	at org.eclipse.rcptt.tesla.recording.aspects.RecordingAspect.ajc$around$org_eclipse_rcptt_tesla_recording_aspects_RecordingAspect$5$a74609ac(RecordingAspect.aj:167)
	at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1262)
	at org.eclipse.swt.widgets.Widget.sendEvent_aroundBody2(Widget.java:1056)
	at org.eclipse.swt.widgets.Widget$AjcClosure3.run(Widget.java:1)
	at org.eclipse.rcptt.tesla.recording.aspects.RecordingAspect.ajc$around$org_eclipse_rcptt_tesla_recording_aspects_RecordingAspect$2$2f127892proceed(RecordingAspect.aj:1)
	at org.eclipse.rcptt.tesla.recording.aspects.RecordingAspect.ajc$around$org_eclipse_rcptt_tesla_recording_aspects_RecordingAspect$2$2f127892(RecordingAspect.aj:118)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1055)
	at org.eclipse.swt.widgets.Widget.sendEvent_aroundBody4(Widget.java:1081)
	at org.eclipse.swt.widgets.Widget$AjcClosure5.run(Widget.java:1)
	at org.eclipse.rcptt.tesla.recording.aspects.RecordingAspect.ajc$around$org_eclipse_rcptt_tesla_recording_aspects_RecordingAspect$1$bd9fb3e7proceed(RecordingAspect.aj:1)
	at org.eclipse.rcptt.tesla.recording.aspects.RecordingAspect.ajc$around$org_eclipse_rcptt_tesla_recording_aspects_RecordingAspect$1$bd9fb3e7(RecordingAspect.aj:82)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1070)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1066)
	at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations.java:1667)
	at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2151)
	at org.eclipse.swt.widgets.Control.windowProc_aroundBody2(Control.java:4608)
	at org.eclipse.swt.widgets.Control$AjcClosure3.run(Control.java:1)
	at org.eclipse.rcptt.tesla.swt.aspects.EventFilterAspect.ajc$around$org_eclipse_rcptt_tesla_swt_aspects_EventFilterAspect$1$602baf3eproceed(EventFilterAspect.aj:1)
	at org.eclipse.rcptt.tesla.swt.aspects.EventFilterAspect.ajc$around$org_eclipse_rcptt_tesla_swt_aspects_EventFilterAspect$1$602baf3e(EventFilterAspect.aj:19)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4606)
	at org.eclipse.swt.widgets.Canvas.windowProc_aroundBody0(Canvas.java:340)
	at org.eclipse.swt.widgets.Canvas$AjcClosure1.run(Canvas.java:1)
	at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:331)
	at org.eclipse.swt.widgets.Decorations.windowProc_aroundBody0(Decorations.java:1627)
	at org.eclipse.swt.widgets.Decorations$AjcClosure1.run(Decorations.java:1)
	at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1621)
	at org.eclipse.swt.widgets.Shell.windowProc_aroundBody4(Shell.java:2075)
	at org.eclipse.swt.widgets.Shell$AjcClosure5.run(Shell.java:1)
	at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2053)
	at org.eclipse.swt.widgets.Display.windowProc_aroundBody20(Display.java:4977)
	at org.eclipse.swt.widgets.Display$AjcClosure21.run(Display.java:1)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4929)
	at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method)
	at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.java:231)
	at org.eclipse.swt.widgets.Shell.open(Shell.java:1217)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.postProcess(WBWRenderer.java:674)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:649)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1038)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
	at com.cinnober.ttc.lme.LmeTTCApplication.start(LmeTTCApplication.java:110)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: java.lang.ClassNotFoundException: java.util.function.Function
	at java.lang.ClassLoader.findClass(Unknown Source)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:420)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	... 167 more
it seems the JAspect codes blocked org.eclipse.e4.ui.workbench.swt to be load, does anyone know this kind of issue?
[Updated on: Mon, 12 October 2015 04:06] by Moderator
Re: Starting workbench failed [message #1698659 is a reply to message #1698503] Wed, 17 June 2015 02:08 Go to previous message
I just found the cause. Because my AUT has been changed, some Java 8 features has been added(Lambda Expression) . But when I created AUT Launcher, it use default JRE version on my PC, which is Jre 7. To solve this issue need go to "Edit Configuration" page and change Runtime JRE to Jre8.
Previous Topic:[SOLVED] how to get value of childcount to put on variable
Next Topic:Mac OS - Unable to record a test - Socket is closed
Current Time: Sun Jul 20 20:55:42 EDT 2025
Powered by FUDForum. Page generated in 0.24279 seconds
