Home » Modeling » Papyrus » project specific property
project specific property [message #1698399] Mon, 15 June 2015 06:43 Go to next message
Is there a way to put project specific properties to elements?
One way would be to define a project specific stereotype for each element that needs that property - e.g. SIL value, or DOC-Seq - and define a regarding tag.
Is there a more straight-forward way for properties which are not important for model itself but for some post-processing?
Re: project specific property [message #1698402 is a reply to message #1698399] Mon, 15 June 2015 07:05 Go to previous messageGo to next message
Hi Rolf,
In Papyrus 1.1.0/Mars, you can move some profile applications in a different resource (File). Although only one profile application model can be active at the same time, you can switch between different profile applications, which means that you can have different Stereotypes/Values.
In the model explorer, right click on a Package and select Refactor > Externalize Profile Applications
The separate profile applications can be manipulated from the Package's properties view ("Applications" tab)
Camille
Re: project specific property [message #1698406 is a reply to message #1698402] Mon, 15 June 2015 07:41 Go to previous messageGo to next message
Thank you Camille. I see, this is not available in Kepler version. Mars will be released end of this month. Worth waiting.
Assume a model that did not use a profile. (Can I call that "based on Standard-Profile" or is that some sort of build-in plain-UML?)
In a new profile if I would extend some element types available as Metaclasses in the Standard Profile e.g. Class, Association, ..., would I be able to enter a property value in a property that were not available before in my model? Introduced by a new Tag in the new profile extending Standard Profile?
Re: project specific property [message #1698408 is a reply to message #1698406] Mon, 15 June 2015 07:46 Go to previous messageGo to next message
Sorry, I am currently using Luna version.
Re: project specific property [message #1698412 is a reply to message #1698408] Mon, 15 June 2015 07:57 Go to previous messageGo to next message
I think you are confusing the UML Metamodel (Defining Class, Association, ...) and the UML Standard Profile, which is actually a Profile, defining some Stereotypes (<<Derive>>, <<Refine>>, <<Metaclass>>, ....)
A Profile defines some Stereotypes, and Stereotypes can "extend" (Via an "Extension") a UML Metaclass, or inherit (Via a "Generalization") from another Stereotype.
You can add new Profiles and/or new Stereotypes and/or new Properties on any model, at any point in time
Camille
Re: project specific property [message #1698445 is a reply to message #1698412] Mon, 15 June 2015 14:02 Go to previous messageGo to next message
Thank you, Camille - i think you are right, my whish is not the way it will go.
Doing a model I did not use any profile, just plain UML.
After that I found out that I need non-standard properties, e.g. for elements like Class, Association, ... , properties like SIL, DOC-SEQ, ...
Now I am going to define a profile for that.
In <<EPackage>> Standard Profile I find the <Package Import>UML 2.5.0 Metamodel, where I can extend the Metaclasses, say I do me a new Class stereotype extending Class and a new Association stereotype extending Association from UML 2.5.0 Metamodel, giving them the required new properties, e.g. SIL, DOC-SEQ...
I guess I have to exchange any plain-UML element in my plain-UML model by my new stereotypes in order to get hold of the properties, right?
Do you know of any other way to attach project-specific information to UML elements?
Is using comments the only way?
Rolf
[Updated on: Mon, 15 June 2015 14:03] by Moderator
Re: project specific property [message #1698515 is a reply to message #1698445] Tue, 16 June 2015 03:47 Go to previous message
Hi Rolf,
Stereotypes is actually the right concept for this. You don't "replace" UML Elements with a Stereotype. Instead, you "apply" a Stereotype on an existing UML Element (Class, Association, ...), to add the extra information you need
HTH,
Camille
Previous Topic:Change size of decorations for associations
Next Topic:Status SysML 1.4 @Mars
Current Time: Mon Jul 21 07:20:23 EDT 2025
Powered by FUDForum. Page generated in 0.04913 seconds
