Home » Eclipse Projects » RCP Testing Tool » RCPTT doesn't recognize my program has started.
RCPTT doesn't recognize my program has started. [message #1698290] Fri, 12 June 2015 18:21 Go to next message
When I select my AUT it works just fine, but when I try to start a new recording my program starts up just fine, but the losing bar gets stuck about 3/4 of the way there rather then pulling up the recording tools.
If instead I try to manually write a script and run it, the progress bar in the bottom right gets to 76% quickly and then very slowly fills up one by one to about 91% before giving me a timeout error.
So far I have tried re exporting my project, restarting everything possible, and adding -nosplash to my run configuration. Any other ideas as to what is causing this issue?
Re: RCPTT doesn't recognize my program has started. [message #1698374 is a reply to message #1698290] Mon, 15 June 2015 03:58 Go to previous messageGo to next message
This is a repeat of the thread below it if a mod wants to delete it. I didn't realize the other one went through because it still hadn't shown up in 24 hours.
Re: RCPTT doesn't recognize my program has started. [message #1710157 is a reply to message #1698374] Mon, 05 October 2015 03:01 Go to previous message
Hi Connor,
Do you still have this issue?
Could you please try RCPTT 2.0.1 and check if the problem still exists?
Kind regards,
Ulyana.
Previous Topic:RCPTT not triggering table row selection listener
Next Topic:The tool can be used for RAP application?
Current Time: Sun Jul 20 23:11:14 EDT 2025
Powered by FUDForum. Page generated in 0.07326 seconds
