Home » Newcomers » Newcomers » Setup project references in Eclipse PHP(Setup project references in Eclipse PHP)
Setup project references in Eclipse PHP [message #1698197] Fri, 12 June 2015 01:51 Go to next message
Hi all,
I used to work with Visual Studio. It was easy to add another project reference (say project B) to an existing project (say project B). When I do that, the project B will be included in the the project A as a dll file.
I am trying to do the same thing on Eclipse PHP. I tried many ways: adding the project B in "Include Path"; "Configure Build Path" to add resource folder. But neither works when I run my application using XAMPP.
Is there any way I could do this? Please instruct me.
Thank you for your support.
Re: Setup project references in Eclipse PHP [message #1698294 is a reply to message #1698197] Fri, 12 June 2015 19:43 Go to previous message
On 06/12/2015 01:55 AM, geraint dong wrote:
> Hi all,
> file.
As we approach the weekend, the Eclipse forums tend to die down a bit.
However, for the fastest response, you will want to ask your PHP
question in the Eclipse PDT forum, no?
Previous Topic:CSD for Eclipse
Next Topic:Converting Output to a pdf file
Current Time: Sat Jul 26 06:52:31 EDT 2025
Powered by FUDForum. Page generated in 0.09810 seconds
