Home » Language IDEs » PHP Development Tools (PDT) » Variable warnings no longer showing (again) - pdt-extensions.
Variable warnings no longer showing (again) - pdt-extensions. [message #1698108] Thu, 11 June 2015 07:24 Go to next message
A while ago I asked about variable warnings, now I am trying to do a clean install again, and I want to get my warnings back.
So I headed over to the pdt-extensions site, entered the url in my "Available Software Sites"
But none of the options I see seem to fit the advice given a few months ago.
index.php/fa/22140/0/
If I select "PDT Extentions" then I get errors, (basically there is a conflict in dependencies).
I got the latest eclipse from, https://eclipse.org/pdt/ and then tried to install the extensions.
What am I missing here?
Cannot complete the install because of a conflicting dependency.
  Software being installed: PDT Extensions 0.21.0.201505272153 (org.pdtextensions.feature.feature.group 0.21.0.201505272153)
  Software currently installed: PHP Development Tools (PDT) 3.3.0.201406110111 (org.eclipse.php.feature.group 3.3.0.201406110111)
  Only one of the following can be installed at once:
    PDT Core Plug-in 3.4.0.201502171754 (org.eclipse.php.core 3.4.0.201502171754)
    PDT Core Plug-in 3.3.0.201406110111 (org.eclipse.php.core 3.3.0.201406110111)
    PDT Core Plug-in 3.3.1.201409161013 (org.eclipse.php.core 3.3.1.201409161013)
    PDT Core Plug-in 3.5.0.201506101836 (org.eclipse.php.core 3.5.0.201506101836)
  Cannot satisfy dependency:
    From: PHP Development Tools (PDT) 3.3.0.201406110111 (org.eclipse.php.feature.group 3.3.0.201406110111)
    To: org.eclipse.php.core [3.3.0.201406110111]
    From: PDT Extensions Core Plugin 0.21.0.201505272153 (org.pdtextensions.core 0.21.0.201505272153)
    To: bundle org.eclipse.php.core 3.5.0
    From: PDT Extensions 0.21.0.201505272153 (org.pdtextensions.feature.feature.group 0.21.0.201505272153)
    To: org.pdtextensions.core [0.21.0.201505272153]
S.
  • Attachment: ext.png
    (Size: 6.27KB, Downloaded 2394 times)
Re: Variable warnings no longer showing (again) - pdt-extensions. [message #1698149 is a reply to message #1698108] Thu, 11 June 2015 11:24 Go to previous messageGo to next message
Latest Core-Plugin require minimum PDT 3.5 (current nightly, will be released together with mars). Both, 3.5 and DLT 5.2 are available in http://p2-dev.pdt-extensions.org/., so please also select category "PHP Development Tools", and "contact all sites during update".
Re: Variable warnings no longer showing (again) - pdt-extensions. [message #1698198 is a reply to message #1698149] Fri, 12 June 2015 02:24 Go to previous messageGo to next message
Dawid Pakula wrote on Thu, 11 June 2015 15:24
If I select "PHP Development Tools (PDT)" and I make sure I have "Contact all update...", I get the following,
Your original request has been modified.
  "PHP Development Tools (PDT)" is already installed, so an update will be performed instead.
Cannot complete the install because one or more required items could not be found.
  Software being installed: PHP Development Tools (PDT) 3.5.0.201506101836 (org.eclipse.php.feature.group 3.5.0.201506101836)
  Missing requirement: PHP Development Tools (PDT) 3.5.0.201506101836 (org.eclipse.php.feature.group 3.5.0.201506101836) requires 'org.eclipse.dltk.core.feature.group 5.2.0' but it could not be found
It says, "...update will be performed instead...", But I cannot install anything.
if I chose "PDT Extensions", (and "Contact all update...") by itself, I get
I am doing a clean install, maybe I should get eclipse without PDT?
S.
Re: Variable warnings no longer showing (again) - pdt-extensions. [message #1698199 is a reply to message #1698198] Fri, 12 June 2015 02:28 Go to previous messageGo to next message
Please update to DLTK 5.2 first. It's available under p2-dev also. Kepler have a bug with auto-updates
Features in category Dynamic Languages Toolkit,:
* DLTK Core Frameworks
* DLTK Core H2 Index Frameworks
Re: Variable warnings no longer showing (again) - pdt-extensions. [message #1698206 is a reply to message #1698199] Fri, 12 June 2015 03:41 Go to previous messageGo to next message
Dawid Pakula wrote on Fri, 12 June 2015 06:28
Thanks, I got it from https://eclipse.org/dltk/ because it does not appear under p2-dev
Also, you mention Kepler, but I am using Luna 4.4.2
Having said that, after installing dltk 5.2 as well as "PDT Extensions" and "PHP Development Tools (PDT)" all is well now and my install is up to date.
Can I now remove the update sites,
http://download.eclipse.org/technology/dltk/updates-dev/5.2/ and
http://download.eclipse.org/tools/pdt/updates/latest-nightly
The reason I ask is because 5.2 will not be updated as far as I can read and pdt will be updated by p2?
S.
Re: Variable warnings no longer showing (again) - pdt-extensions. [message #1698208 is a reply to message #1698206] Fri, 12 June 2015 03:49 Go to previous messageGo to next message
Yes, you can remove these sites.
I'll check later why DLTK 5.2 isn't available in p2-dev.
Re: Variable warnings no longer showing (again) - pdt-extensions. [message #1698281 is a reply to message #1698208] Fri, 12 June 2015 14:44 Go to previous message
I have now started to get the same message as in my previous post, https://www.eclipse.org/forums/index.php?t=msg&th=1067203&goto=1698280&#msg_1698280
Any suggestions?
S.
Previous Topic:JDST 1.6.0
Next Topic:org.eclipse.php.internal.debug.core error
Current Time: Sat Jul 26 15:24:12 EDT 2025
Powered by FUDForum. Page generated in 0.03967 seconds
