Random failure building update site [message #16981] |
Wed, 21 May 2008 09:15  |
Originally posted by: cbutt.iona.com
I'm using Buckminster in headless mode to build my plugins and features.
During the building of the update site I get an error similar to the one
at the end of this message. However, if I run the same build on another
machine it sometimes passes. I have even had the build fail in headless
mode, opened up the workspace in the GUI and built the update site
without any problems. I'm using the latest version of Buckminster
(r09175 of the archived site and r09116 of the product) in headless mode
on Linux (both 32 and 64 bit). Is there any way to see what file/element
it is looking for? Is this a bug?
Chris
[09:37:22]: [java]
org.eclipse.buckminster.core.metadata.model.ElementNotFoundE xception: No
element with id db73b4bc-3472-32fd-9859-3b2798bb1b46 was found in
storage resolution
[09:37:22]: [java] at
org.eclipse.buckminster.core.metadata.FileStorage.getCreatio nTime(FileStorage.java:231)
org.eclipse.buckminster.core.metadata.WorkspaceInfo.getActiv eResolutions(WorkspaceInfo.java:665)
org.eclipse.buckminster.core.metadata.WorkspaceInfo.getResol ution(WorkspaceInfo.java:429)
org.eclipse.buckminster.core.metadata.ModelCache.findCSpec(M odelCache.java:54)
org.eclipse.buckminster.core.cspec.model.CSpec.getReferenced Attribute(CSpec.java:925)
org.eclipse.buckminster.core.cspec.model.Prerequisite.getRef erencedAttribute(Prerequisite.java:91)
org.eclipse.buckminster.core.cspec.model.Prerequisite.isEnab led(Prerequisite.java:150)
org.eclipse.buckminster.core.cspec.model.Group.isEnabled(Gro up.java:162)
org.eclipse.buckminster.core.cspec.model.CSpec.getReferenced Attribute(CSpec.java:929)
org.eclipse.buckminster.core.internal.actor.PerformManager.a ddAttributeChildren(PerformManager.java:334)
org.eclipse.buckminster.core.internal.actor.PerformManager.a ddAttributeChildren(PerformManager.java:336)
org.eclipse.buckminster.core.internal.actor.PerformManager.g etOrderedActionList(PerformManager.java:303)
org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:94)
org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:75)
org.eclipse.buckminster.core.commands.Perform.internalRun(Pe rform.java:68)
org.eclipse.buckminster.core.commands.WorkspaceCommand.run(W orkspaceCommand.java:45)
org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(Abs tractCommand.java:80)
org.eclipse.buckminster.cmdline.Headless.run(Headless.java:1 88)
org.eclipse.buckminster.cmdline.Headless.run(Headless.java:1 22)
org.eclipse.buckminster.cmdline.Headless.start(Headless.java :113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[09:37:22]: [java] at java.lang.reflect.Method.invoke(Method.java:585)
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
org.eclipse.equinox.launcher.Main.run(Main.java:1173)
org.eclipse.equinox.launcher.Main.main(Main.java:1148)
[09:37:22]: [java] No element with id
db73b4bc-3472-32fd-9859-3b2798bb1b46 was found in storage resolution
Re: Random failure building update site [message #17128 is a reply to message #16981] |
Thu, 22 May 2008 14:17  |
Hi Chris,
Does this happen on a specific workspace or on a workspace that you
create from scratch? From the sound of it, you might have some corrupt
meta-data so if it is a specific workspace, I'd recommend that you
remove the folder
<workspace>/.metadata/.plugins/org.eclipse.buckminster.core
Thomas Hallgren
Chris Butt wrote:
> Chris
> [09:37:22]: [java]
> storage resolution
FUDForum. Page generated in 0.05866 seconds
