Home » Eclipse Projects » e(fx)clipse » initModality in PartDescriptor (for new window)
initModality in PartDescriptor (for new window) [message #1698031] Wed, 10 June 2015 09:39 Go to next message
If I create partDescriptor with:
@Inject
private Stage stage;
@PostConstruct
public void postConstruct()
 stage.initModality( Modality.APPLICATION_MODAL );
everything works.
But I want to have one partDescriptor and set modality "on the fly".
How can I do that?
It must be set before part set visible, but MPart.getObject() Quote:
It will only be non-null if the element has been rendered into the presentation
, so I can't set it after that.
Re: initModality in PartDescriptor (for new window) [message #1698038 is a reply to message #1698031] Wed, 10 June 2015 09:57 Go to previous messageGo to next message
You can not modify the modality once a stage is shown. So you need to
make this decision at startup!
Tom
On 10.06.15 15:39, Bart Cichy wrote:
> Hello,
> @Inject
> @PostConstruct
> everything works.
> How can I do that?
>> presentation
Re: initModality in PartDescriptor (for new window) [message #1698064 is a reply to message #1698031] Wed, 10 June 2015 14:19 Go to previous messageGo to next message
Yes, I known it. But I want to have one partDescriptor and before send to renderer (set visible) I want to programmatically set Modality.WINDOW_MODAL / Modality.APPLICATION_MODAL. Can I do it somehow on the fly with one partDescriptor or I must set second partDescriptor with this setting?
Re: initModality in PartDescriptor (for new window) [message #1698065 is a reply to message #1698064] Wed, 10 June 2015 14:39 Go to previous messageGo to next message
I repeat this makes no real sense! If you want a window to be modal use set the appropriate state in the model - see http://wiki.eclipse.org/Efxclipse/Runtime/e4#MWindow
Re: initModality in PartDescriptor (for new window) [message #1698068 is a reply to message #1698031] Wed, 10 June 2015 14:55 Go to previous messageGo to next message
But I don't see any state to modal:
- scene.3d
- decoration
- StageStyle
- fullscreen
- shellMaximized (tag)
[Updated on: Wed, 10 June 2015 14:57] by Moderator
Re: initModality in PartDescriptor (for new window) [message #1698096 is a reply to message #1698068] Thu, 11 June 2015 04:10 Go to previous messageGo to next message
You are right! Please file a bugzilla so that we allow to control the
modality as well.
Tom
> - scene.3d
> - decoration
> - StageStyle
> - fullscreen
> - shellMaximized
Re: initModality in PartDescriptor (for new window) [message #1698106 is a reply to message #1698096] Thu, 11 June 2015 06:49 Go to previous messageGo to next message
bug 469920
Re: initModality in PartDescriptor (for new window) [message #1698227 is a reply to message #1698106] Fri, 12 June 2015 07:08 Go to previous message
https://wiki.eclipse.org/Efxclipse/Runtime/e4#MWindow
Tom
On 11.06.15 12:49, Bartlomiej Cichocki wrote:
> bug 469920
Previous Topic:@PreClose in PartDescriptor
Next Topic:Howto pass parameter to contribution class
Current Time: Sun Aug 31 02:51:34 EDT 2025
Powered by FUDForum. Page generated in 0.04722 seconds
