Home » Eclipse Projects » Sirius » Display Selection Wizard at Java Service
Display Selection Wizard at Java Service [message #1697873] Tue, 09 June 2015 05:51 Go to next message
I defined a Selection Wizard.
I would like to open it from Java Service call, for example when click on a popup menu.
How can i do that?
Thanks.
Huy.
Re: Display Selection Wizard at Java Service [message #1697906 is a reply to message #1697873] Tue, 09 June 2015 10:01 Go to previous messageGo to next message
For the Java Service call, you have two solutions:
- you write a simple java class with your service in it. In your VSM,
you only need to declare the java class as a Java Extension (sub element
of the Representation Description element (i.e. diagram description). In
your service you can directly call the service in the interpreted
expressions. You can find more information about Java Services[1] on the
online documentation.
- you can declare a java extension using the
"org.eclipse.sirius.externalJavaAction". This way you can execute the
service using an operation External Java Action Call (instead of using
the java method name in the interpreted expressions). You can find more
information about External Java Action[2] on the online documentation.
For the Selection Wizard part, it should be called by your java service.
The code you want to call is
"org.eclipse.sirius.common.ui.tools.api.selection.EObjectSelectionWizard" and
"org.eclipse.sirius.common.ui.tools.api.selection.page.EObjectSelectionWizardPage".
You can find examples in
"org.eclipse.sirius.diagram.ui.tools.internal.commands.emf.SelectionWizardCommand".
Steve
[1]
https://www.eclipse.org/sirius/doc/specifier/general/Writing_Queries.html#service_methods
[2]
https://www.eclipse.org/sirius/doc/specifier/general/Model_Operations.html#extensions
Le 09/06/2015 11:51, Huy Le a écrit :
> Hello,
> on a popup menu.
> How can i do that?
> Thanks.
> Huy.
Steve Monnier - Obeo
Need professional services for Sirius?
Re: Display Selection Wizard at Java Service [message #1698012 is a reply to message #1697906] Wed, 10 June 2015 07:22 Go to previous messageGo to next message
Hello Steve,
I would like to give more detail on the issue.
- The wizard is defined in .odesign
- Several entry points need to re-use the same wizard suche as popup menu A, popup menu B, via Palette tool,.etc..
The question is: How to retrieve or to reuse the Wizard already defined in .odesign?
Thanks.
Huy.
Re: Display Selection Wizard at Java Service [message #1698041 is a reply to message #1698012] Wed, 10 June 2015 10:54 Go to previous message
Hello Huy,
You cannot call a Selection Wizard Tool from an operation of another
tool (popup or palette). This is why I think you should have a java
service either as a Java Extension or an External Java Action that calls
this wizard (cf my previous reply). This way you will be able to reuse
the same wizard in many tools.
Steve
Le 10/06/2015 13:22, Huy Le a écrit :
> Hello Steve,
> in .odesign?
> Thanks.
> Huy.
Previous Topic:Conditions sur des valeurs
Next Topic:Edit semantic model programmatically
Current Time: Sun Jul 27 11:21:31 EDT 2025
Powered by FUDForum. Page generated in 0.03994 seconds
