Re: Display Selection Wizard at Java Service [message #1698041 is a reply to message #1698012] |
Wed, 10 June 2015 10:54  |
Hello Huy,
You cannot call a Selection Wizard Tool from an operation of another
tool (popup or palette). This is why I think you should have a java
service either as a Java Extension or an External Java Action that calls
this wizard (cf my previous reply). This way you will be able to reuse
the same wizard in many tools.
Steve
Le 10/06/2015 13:22, Huy Le a écrit :
> Hello Steve,
> I would like to give more detail on the issue.
> - The wizard is defined in .odesign
> - Several entry points need to re-use the same wizard suche as popup
> menu A, popup menu B, via Palette tool,.etc..
> The question is: How to retrieve or to reuse the Wizard already defined
> in .odesign?
> Thanks.
> Huy.
Steve Monnier - Obeo
Need professional services for Sirius?
FUDForum. Page generated in 0.19603 seconds
