Home » Eclipse Projects » Oomph » How to disable the Preference Recorder
How to disable the Preference Recorder [message #1697881] Tue, 09 June 2015 06:38 Go to next message
I have installed Eclipse Mars RC3 (on Ubuntu 15.04) manually by unpacking a tar.gz archive. Nonetheless I seem to have the Oomph functionality, part of which is the Preference Recorder.
I do not want this functionality and hate the prompting it does when I change preferences. My Eclipse Preferences shows a checkmark indicating the Preference Recorder is enabled but I can not disable it. The prompt does allow me to uncheck Preference Recorder activity but that does nothing noticeable.
Can I completely uninstall Oomph? If that is not possible, how can I disabe the Preference Recorder altogether?
Thanks very much in advance.
Silvio
Re: How to disable the Preference Recorder [message #1697933 is a reply to message #1697881] Tue, 09 June 2015 12:17 Go to previous messageGo to next message
Silvio,
Comments below.
> change preferences.
There are quite a few things in each package that I don't want...
That sounds like https://bugs.eclipse.org/bugs/show_bug.cgi?id=469652
which is fixed. (And I think is only a problem if your user.setup
specified the default to be true; perhaps you used the questionnaire a
few months back.)
In RC4 you can disable it.
You really have no global preferences you want across all workspaces.
Pretty much everyone does. E.g., line numbers in editors... UTF-8 as
the default file encoding...
> Silvio
Re: How to disable the Preference Recorder [message #1697959 is a reply to message #1697933] Tue, 09 June 2015 17:09 Go to previous messageGo to next message
No, I don't. I do have preferences that may span workspaces but these preferences also span applications I use, machines I work on and so on.
Putting something as invasive and heavyweight as this in Eclipse for such a futile task (setting some preferences in workspaces I have about 2-3 at the same time and each of those for multiple years) I consider an extreme form of over-engineering. What was wrong with exporting and then importing the same preferences across workspaces? A much more powerful method that also works when I get a new laptop.
But it is good to know I can opt out of this in RC4.
Thank you.
Re: How to disable the Preference Recorder [message #1697981 is a reply to message #1697959] Wed, 10 June 2015 01:17 Go to previous messageGo to next message
Silvio,
Comments below.
I doubt that, but again, there's no point in preaching to those who
don't want to hear.
You certainly use heavyweight wording...
We're all entitled to opinions.
> across workspaces?
Do you actually do that? I can enumerate a long list of what's wrong
with that. E.g., all my git clones remembered but Egit replace the ones
I have in my workspace. Kind of a disaster for me. But it sounds like
your limited use cases for it work fine for you.
Perhaps, but many preferences refer to hard-coded locations that are
different on different machines.
We aim to please, but there's no pleasing everyone.
> Thank you.
Re: How to disable the Preference Recorder [message #1698003 is a reply to message #1697981] Wed, 10 June 2015 05:49 Go to previous messageGo to next message
I can accept that there are use-cases where something like the Preference Recorder might be useful and even an improvement over existing methods. I have little use for many workspaces at the same time (unless for the reason of testing Eclipse versions that need to convert a workspace into something that will not work with earlier versions) but that is because my company provides only a couple of standard products we work on for years in a row. I know others continously create new projects and possibly workspaces so there is no one-size-fits-all solution.
But why not implement such a thing as a plug-in? That way everyone who needs it can opt-in on the functionality or ignore it if they don't want it.
Anyway, seems like in RC4 the problem went away on its own. Perhaps because it is a plug-in now?
Re: How to disable the Preference Recorder [message #1698013 is a reply to message #1698003] Wed, 10 June 2015 07:29 Go to previous messageGo to next message
Am 10.06.2015 um 11:49 schrieb Silvio Bierman:
Of course it's a plug-in and users can opt-in unless they use a product that contains this plug-in by default. The
products you can download from Eclipse's download pages are governed by the Eclipse Packaging project (EPP) and they've
decided to include our (the Oomph project's) plug-in in all their products.
Neither EPP nor Oomph have provided RC4 builds, yet. Our's will come today, EPP's on Friday.
No, Ed has fixed https://bugs.eclipse.org/bugs/show_bug.cgi?id=469652 as he pointed out in an earlier reply.
Eclipse tools are always plug-ins.
Cheers
/Eike
http://www.esc-net.de
Re: How to disable the Preference Recorder [message #1765188 is a reply to message #1698013] Wed, 07 June 2017 07:15 Go to previous messageGo to next message
I am new to Oomph,I want to attach target file,code style and sonar lint into the installer so that I can get it preset in eclipse instance with my project from git.So please let me know how to do it?
Re: How to disable the Preference Recorder [message #1765218 is a reply to message #1765188] Wed, 07 June 2017 11:29 Go to previous message
I'm not sure how this is related to the thread you posted on...
Use Navigate -> Open Setup -> Parent Models -> Catalog Index and look at how other projects in the Eclipse Projects catalog have authored their setups. Refer to the information in https://wiki.eclipse.org/Eclipse_Installer#Tutorials for basics and ask a specific questions after that (on a sensible thread related to your questions).
Previous Topic:Using oomph's setup project model on a shared Install
Next Topic:Oomph target platform setup
Current Time: Sat Jul 26 23:24:50 EDT 2025
Powered by FUDForum. Page generated in 0.05548 seconds
