Eclipse build errors [message #1663868] |
Tue, 10 March 2015 12:33  |
Dear Kura Members,
Using the Getting Started instructions I have successfully built the target platform and core components. But after Importing and building projects in Eclipse I am getting two Errors.
Error 1: Java Problem
The declared package "org.eclipse.kura.deployment.customizer.upgrade.rp" does not match the expected package "main.java.org.eclipse.kura.deployment.customizer.upgrade.rp" Activator.java /org.eclipse.kura.deployment.customizer.upgrade/src/main/java/org/eclipse/kura/deployment/customizer/upgrade/rp
Error 2: Maven Problems
Project build error: Non-resolvable parent POM: Failure to find org.eclipse.kura:kura:pom:1.1.0 in repo.maven.apache.org was cached in the local repository, resolution will not be reattempted until the update interval of central has elapsed or updates are forced and 'parent.relativePath' points at wrong local POM pom.xml /org.eclipse.kura.qa line 18 Maven pom Loading Problem
Any help would be appreciated...
Best Regards,
Jishnu Nair
Re: Eclipse build errors [message #1698073 is a reply to message #1697980] |
Wed, 10 June 2015 16:27  |
Shiv,
The errors appear to be in the Bluetooth example. Can you right click on org.eclipse.kura.example.ble.tisensortag and select 'Properties'. Once their, Select 'Java Build Path', then select the 'Libraries' tab. Do you see an entry for 'Plug-in Dependencies'? If not:
Select 'Add Library...'
Select 'Plug-in Dependencies', then click 'Next >'
Click 'Finish'
--Dave
FUDForum. Page generated in 0.03746 seconds
