Home » Eclipse Projects » e(fx)clipse » Using contextvalue leads me to curious IllegalStateException
Using contextvalue leads me to curious IllegalStateException [message #1697880] Tue, 09 June 2015 06:24 Go to next message
During applicaton startup, I use a ContextBoundValue<String> to keep track of the progress made of the user who tries to log into the application.
This value gets published (very normally) in the fxml controller of the loginscreen, like this :
@Inject
@ContextValue(LoginManager.LOGIN_STATUS_CONTEXT_KEY)
private ContextBoundValue<String> loginStatus ;
loginStatus.publish(LoginManager.LOGIN_STATUS_OK);
And I have the proof this publishing works correctly :
DEBUG: 2015-06-09 11:57:43 [JavaFX Application Thread] LifecycleManager - Login status : loginStatusOk
But why then do I also get this stack trace ? Most noticebly, it says "java.lang.IllegalArgumentException: Variable be.groups.portfolio.loginstatus is not modifiable in the context WorkbenchContext", as stated below :
Exception in thread "JavaFX Application Thread" java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
at javafx.fxml.FXMLLoader$MethodHandler.invoke(FXMLLoader.java:1770)
at javafx.fxml.FXMLLoader$ControllerMethodEventHandler.handle(FXMLLoader.java:1653)
at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:86)
at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:238)
at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:191)
at com.sun.javafx.event.CompositeEventDispatcher.dispatchBubblingEvent(CompositeEventDispatcher.java:59)
at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:58)
at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114)
at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56)
Caused by: java.lang.IllegalArgumentException: Variable be.groups.portfolio.loginstatus is not modifiable in the context WorkbenchContext
at org.eclipse.e4.core.internal.contexts.EclipseContext.internalModify(EclipseContext.java:385)
at org.eclipse.e4.core.internal.contexts.EclipseContext.modify(EclipseContext.java:375)
at org.eclipse.fx.core.di.context.internal.EclipseContextBoundValue.publish(EclipseContextBoundValue.java:119)
at login.LoginScreenController.setLoginStatus(LoginScreenController.java:128)
at login.LoginScreenController.handleConfirm(LoginScreenController.java:91)
... 95 more
I do not understand what it means, nor what it implies...
The lifecylemanager gets injected with a @Singleton @Creatable LoginManager,
this loginManager loads the loginscreen,
the controller of the loginscreen publishes the value,
and finally, the lifecyclemanager reads the value when the loginscreen is closed.
Shouldn't I assume those three classes are accessing the same context ?
Anybody a clue ?
Thanks for any advice,
Thomas Elskens
Re: Using contextvalue leads me to curious IllegalStateException [message #1697882 is a reply to message #1697880] Tue, 09 June 2015 06:40 Go to previous messageGo to next message
It does not matter on which context the important thing is that you need
to tell the system in which context the value is tracked.
To do this you need to call on the IEclipseContext you want the value to
reside
IEclipseContext#declareModifiable(LoginManager.LOGIN_STATUS_CONTEXT_KEY).
In your case this is most likely the Root-Context.
Tom
> application.
> @Inject
> Quote:
> Quote:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> WorkbenchContext
>> at
>> at
>> at
>> at
>> at
>> ... 95 more
> LoginManager,
> is closed.
> Anybody a clue ?
> Thomas Elskens
Re: Using contextvalue leads me to curious IllegalStateException [message #1697895 is a reply to message #1697882] Tue, 09 June 2015 08:15 Go to previous message
Okay this works, thanks a lot !
Previous Topic:The import javafx cannot be resolved
Next Topic:Detaching views using DnD
Current Time: Sun Jul 20 21:24:23 EDT 2025
Powered by FUDForum. Page generated in 0.07649 seconds
